![]() | Home > Maintenance & Mods (L322) > Brakes, to grease or not to grease, that is the quesation |
| Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137
I am fitting new rear pads and disks.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35878
this is what it says in the WM so i would say yes..
| Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 714
Mating surfaces means where the pads slide in the caliper NOT between the pad & piston(s) .
ah, that makes sense |
Don't add grease to the back of the pads - it does nothing positive !
It's worth adding that NO vehicle OR brake manufacturer uses grease between the pads & pistons to stop squeal.
Thanks for all the reply’s, if only I had the relevant page of the workshop manual. |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883
Q.E.D.
I'm very surprised if the Land Rover manual suggests using grease between pads & pistons.
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218
So where do you put the grease then? |
| Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1483
The page that Baltic Blue posted is from the 2010-2012 WM 2021 D350 Fifty Edition - Carpathian Grey
I'm busy looking for a hat to eat - lol. |
| nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690
The new genuine pads I've just put on the front (6 pot brembo calipers) had a sticky adhesive layer on the back of each pad too. 2021 D350 Fifty Edition - Carpathian Grey 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
| All times are GMT |
