Home > Technical (L322) > Re-engine or scrap? |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1227 |
It may not be relevant (probably not!), but I think it may have been back in 2006 we had a 4.6 P38 Range Rover which at the time was I think around 7-8 years old.
16th Apr 2018 2:48pm |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 701 |
crankshaft has overheated and is now out of true
16th Apr 2018 4:15pm |
crowebeard Member Since: 19 Dec 2016 Location: Devon Posts: 93 |
Paul - Thanks for the suggestion, I will do some digging around and see if sourcing a short engine would be viable.
16th Apr 2018 4:30pm |
I've just been reading your other post about the head gasket failure. Hadnt realised it was an LPG conversion. The noise isn't something to do with the LPG conversion is it? |
17th Apr 2018 1:16pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3057 |
have you thought about your chains adn guides? they make a horrible noise when the guides go! Costs c. £3,000 for replacement. (I know Ive been there. However all good now - on 191,000 miles) ..... |
17th Apr 2018 2:11pm |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 326 |
I wouldn’t necessarily rule out ebay
17th Apr 2018 3:02pm |
Thanks for the help guys, I went over to the garage today and had another look. I got them to start it up and manged to grab a few seconds of video.
17th Apr 2018 5:13pm |
To me that doesn't sound like a crankshaft issue. I used to have a Triumph Spitfire and the oil pump failed on the M6 which caused one of the big ends to cream the bearing shell. The engine still ran but it was making a really deep 'thumping' sound.
17th Apr 2018 5:32pm |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 354 |
I wouldn't necessarily discount ebay.
17th Apr 2018 7:20pm |
You're right, I should perhaps be a bit more open minded about ebay, but the I didn't want to run the risk of going through all this hassle again.
17th Apr 2018 8:14pm |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
Timing chains sounds like a good shout. Slapping onto the guides. Guides broken up.
17th Apr 2018 8:38pm |
wood78987 Member Since: 03 Mar 2016 Location: South Wales Posts: 131 |
That doesn't sound like timing chain guides to me. Mine was much more rattley than that. That sounds more lumpy. 2012 Westminster 4.4 TDV8 (sold)
17th Apr 2018 10:29pm |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
Also sounds like it's struggling to start ie, low compression. Cam chain guides wouldn't cause that either. |
17th Apr 2018 10:39pm |
Well there are noises, doesn’t sound too metallic to me.
18th Apr 2018 1:14am |
