Home > Technical (L322) > Gearbox/Transfer Box failure
Rich_Allen
Hi all,
Thoughts on this please... I know I am going to have to drop the transfer box at very least... but could this be output shaft of gearbox doing its splines? Sad
Last weekend was driving out of a village at about 30/35mph under no real load when I heard a pop and had no drive..
Today was first time i’ve Had a chance to have a look underneath and this is what happens etc..
One video is me lying underneath rotating a rear wheel. Other is the noise it makes when put in drive. It does not hold in Park...
Cheers 2008 TDV8 Vogue SE
2002 TD6 Vogue
2002 Defender 90 TD5
2002 Range Rover P38 Autobiography
2002 Range Rover P38 Westminster
Just a sucker for big bills!!!
Post #475998 16th Apr 2018 2:42pm
j_rov
Possibly half shaft popping out of diff??? __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #476001 16th Apr 2018 2:56pm
Rich_Allen
Not a Diff, All wheels rotate driveshafts and propshafts...
Problem lies with the transfer box I think... 2008 TDV8 Vogue SE
2002 TD6 Vogue
Post #476008 16th Apr 2018 3:53pm
RRPhil
Were the rear wheels off the ground or on the ground when you were turning the rear propshaft? If they were off the ground you need one further check to see if either propshaft is turning with the vehicle stationary in Drive with all four wheels on the ground. If either propshaft turns then you have a diff/driveshaft problem. If neither propshaft turns then it’s a transfer box/output shaft spline problem.
Phil
Post #476011 16th Apr 2018 4:04pm
alistairh
I was pulling away from a set of lights then lost drive. Front prop was spinning when car was in gear but no drive..the front diff coupling /propshaft had rounded its splines. This was what was happening when you selected drive..it wasn’t an expensive fix either for once
Post #476040 16th Apr 2018 10:38pm
Rich_Allen
Phil
Thanks Phil, will try that one tomorrow but I just know it will be gearbox off... lol 2008 TDV8 Vogue SE
2002 TD6 Vogue
Post #476042 16th Apr 2018 10:44pm
markcartlidge
It happened to me a few months back. easy fix. new coupling etc.
500290 40.00 Front Prop shaft coupler Duckworths
coupling 30.00 Flexible coupler 00012G Duckworths
DA2355 98.09 Front Prop shaft coupler LR Direct
certainly not a big job if it is the splines.
Post #476044 17th Apr 2018 12:17am
RRPhil
The front propshaft spline failure issue was fixed for good when Land Rover moved to the ZF 6HP26/Magna DD295 driveline. Vehicles built after 2006MY - like Rich_Allen’s - weren’t therefore affected by this problem.
Phil
Post #476045 17th Apr 2018 12:47am
rar110
The sound on your first vid is the same sound coming from my L322 when 6hp26 output spline finally let go. Below is a pic with the box out. I replaced both tranny and transfer box as input gear was equally worn. Before the new (used) unit was fitted, which came from same vehicle, I had both ends liberally lubricated.
 ______________________________
Post #476268 19th Apr 2018 9:24pm
Rich_Allen
Yep... just got round to dropping transfer box out..
same scenario...
Transfer box is only wet as I sprayed brake cleaner in to flush the crap out...
 2008 TDV8 Vogue SE
2002 TD6 Vogue
Post #477032 28th Apr 2018 2:40pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
The same happened to my car a few years ago.
Along with fitting a recon transfer box I found a supplier of the shaft as Land Rover do not supply it seperatley.
http://www.bristoltransmissions.co.uk/shop...shaft.html
Post #477034 28th Apr 2018 3:04pm
rar110
RRPhil was quite helpful with tips & advice. This also occurred in the L319 & L320.
Although my box had about 240,000km on it when it failed, it was faultless. Looking at the online vids it didn’t look to hard to rebuild. The output shaft is the last thing in the box to come out.
However as indicated I was lucky to find a low km tranny and TF box from a 2010 FF. The only issue was the transmission control module was not compatible with my 2008 FF. So I ended up using my old mechatronic. I will swap over the valve body one day.
Good luck. ______________________________
Post #477046 28th Apr 2018 7:04pm
RRPhil
I was interested to read Land Rover’s position on this failure in RoverDramas’ post, whose output shaft spline failed on his 6HP28 after only 62000 miles, where they said this was caused by “wear and tear” which was “heavily influenced by driving style”. When RoverDramas questioned if the failure was due to lack of lubrication of the spline, LR's response was “…anti seize grease is applied during the removal and refitting of the transmission. However, this is a service procedure and is not necessarily the same process completed when the vehicle is in the manufacturing process as these parts are fitted dry”
http://www.fullfatrr.com/forum/topic47018.html
Phil
Post #477081 29th Apr 2018 10:49am
