![]() | Home > Technical (L322) > Gearbox/Transfer Box failure |
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 386 ![]() ![]() |
Possibly half shaft popping out of diff??? __
Rich_Allen Member Since: 05 Jan 2015 Location: Rutland Posts: 80 ![]() ![]() ![]() |
Not a Diff, All wheels rotate driveshafts and propshafts...
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1023 ![]() ![]() |
Were the rear wheels off the ground or on the ground when you were turning the rear propshaft? If they were off the ground you need one further check to see if either propshaft is turning with the vehicle stationary in Drive with all four wheels on the ground. If either propshaft turns then you have a diff/driveshaft problem. If neither propshaft turns then it’s a transfer box/output shaft spline problem.
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
I was pulling away from a set of lights then lost drive. Front prop was spinning when car was in gear but no drive..the front diff coupling /propshaft had rounded its splines. This was what was happening when you selected drive..it wasn’t an expensive fix either for once |
Thanks Phil, will try that one tomorrow but I just know it will be gearbox off... lol 2008 TDV8 Vogue SE 2002 TD6 Vogue 2002 Defender 90 TD5 2002 Range Rover P38 Autobiography 2002 Range Rover P38 Westminster Just a sucker for big bills!!! |
markcartlidge Member Since: 18 Mar 2013 Location: Nr Winslow, Buckinghamshire Posts: 120 ![]() ![]() ![]() |
It happened to me a few months back. easy fix. new coupling etc.
The front propshaft spline failure issue was fixed for good when Land Rover moved to the ZF 6HP26/Magna DD295 driveline. Vehicles built after 2006MY - like Rich_Allen’s - weren’t therefore affected by this problem.
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
The sound on your first vid is the same sound coming from my L322 when 6hp26 output spline finally let go. Below is a pic with the box out. I replaced both tranny and transfer box as input gear was equally worn. Before the new (used) unit was fitted, which came from same vehicle, I had both ends liberally lubricated.
Yep... just got round to dropping transfer box out..
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
The same happened to my car a few years ago.
RRPhil was quite helpful with tips & advice. This also occurred in the L319 & L320.
I was interested to read Land Rover’s position on this failure in RoverDramas’ post, whose output shaft spline failed on his 6HP28 after only 62000 miles, where they said this was caused by “wear and tear” which was “heavily influenced by driving style”. When RoverDramas questioned if the failure was due to lack of lubrication of the spline, LR's response was “…anti seize grease is applied during the removal and refitting of the transmission. However, this is a service procedure and is not necessarily the same process completed when the vehicle is in the manufacturing process as these parts are fitted dry”
