![]() | Home > Technical (L322) > Paddle Shift? |
| Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435
And the S/C has the old gearbox - not the new 8 speed. |
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014
Both the ZF 5 speed and 6 speed are steptronic boxes. They are fully electronically controlled, rather than the "auto's of old". Classed as a Semi-Automatic. (even the P38 was electronically controlled and there was a mod to use the cruise or stereo buttons to change gear) It's pretty much the same tech that goes into BMW cars - so the paddle shift feature out of BM's fits our scenario perfectly. The Rover 75 and MG ZT could also have the retrofit, which was at least a little more fitting. There is lots of info all over the interwebs.
| Baben Member Since: 17 Oct 2010 Location: Kyalami Posts: 165
Can't find anyone thats actually done the paddle-shift retrofit to an L322 though. Not even BBSSpy |
| scene247 Member Since: 16 Sep 2010 Location: London Posts: 126
Gaz, Really? I have the 2011MY 4.4 TDV8 and the paddles are marked - and + and only pull towards the wheel. Didn't know just one could control both up and down shifts. I'll have to check later on as that's really quite interesting. Agree with the other part about returning to drive. These are very useful for downshifting without having to floor it for kickdown. Also was very good for use in the snow to slow the car without braking, only braking at last minute to come o stop. I was told these were added as with rotary selector no way of manually shifting. 2010MY had the stick that could be used to shift. |
| kkqd0298 Member Since: 02 Mar 2010 Location: London/Aberdeen Posts: 199
Have a look at the disco forum as several people have converted their discos. TBH It works well with the 8 speed box, but not sure if it is worth it for the 6 speed. *Gone* Discovery3 HSE *Gone* Discovery3 HSE *Gone* MY10 RangeRover TDV8 Freelander for OH MY11 Range Rover 4.4 TDV8 Autobiography Black |
Yes I know. I did the first Disco3 paddle shift installation ever, thanks to wiggs and Colin. I was just hoping the FFRR would not need splicing into wiring looms etc |
I think that's because most owners of RR's haven't thought "you know what I think this car really needs is paddle shift" You don't need to add new cables AFAIK because that's the benefit of digital over analogue signals. You just need 1 cable to carry the data. Here is some info on the retrofit for the early X5's (if it can be done on an X5 it can be done on a RR) http://www.tayam.net/x5/smgwheelonx5.htm More info, more complicated: http://forum.e46fanatics.com/showthread.php?t=63211
Thanks Dan
| Dogman Member Since: 10 Dec 2010 Location: UK Posts: 174
On the BMW E46 you just needed to tap into the signal lines from the gearstick/lever (i.e. to replicate the contact closure when stick is pushed forwards & backwards). A bit heath-robinson but it was an easy retrofit, worked and was reliable.
| Jsb Member Since: 24 Nov 2010 Location: Southampton Posts: 78
i just bought a new wheel, ebay 180 delivered, wanted the smooth leather and mine looked worn. It has turned up and has the paddle shifts.......now i want them to work! will fit the wheel without wiring them up, bit beyond me i reckon.....but if anyone cracks this please let me know. |
Dogman, Gaz,
Sooooo much better than the push/pull (as I'm sure Porsche owners will confirm) |
Confirmed with "The Large One" (on D3 forum) NIck at Yeovil LR that the paddles for the L322 are available separately. I just have to figure out how to connect them then.... |
| All times are GMT |
