![]() | Home > Technical (L322) > Paddle Shift? |
Baben Member Since: 17 Oct 2010 Location: Kyalami Posts: 165 ![]() ![]() ![]() |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
hi Colin, just wanted to ask a few questions,
Baben ... the paddles what do they fix to,is it the steering wheel itself. just had my wheel re-trimmed in two tone , do you have some photos
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
if he has said he has edited his CCF file he must have a post 05 (touch screen model) as pre 05 vehicles didnt have CCF files, thats the whole point of the gateway module.
yes it is a 2010 5.0 s/c
matt if you use the gate way module you can start to use things like the venture cam, it allows our cars to talk to the canbus.. |
hi dave, the gateway module was only used in a very limited run of vehicles from when they fitted the first touch screen system until they redesigned the interior, from then on they combined the gateway module into the instrument cluster. If you do fit a gateway module, how will you be able to use the venture cam? you need the touch screen infotainment system for venture cam to work as the BMW infotainment system does not support venture cam. |
hi matt your right, they only fitted them to the 2005 cars that had the first touch screens and as they started updating the electrics, they are very hard to find... i have had several conversation with bbs spy who prompted me to the gate way module after me telling him i wanted to use the venture cam, also he was working on a module that would allow you to use the 2010 switches on the i bus system.. he is very technical and i have to read his post a few times before it goes in... V8 facelift Range Rover Autobiography 22" wheels.
BBS SPY Member Since: 20 Apr 2009 Location: Limassol Posts: 101 ![]() ![]() ![]() |
Congratulations Baben
some video evidence
thats great but bit of a short video |
well the s/c makes most roads feel short |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1243 ![]() ![]() ![]() |
So at the moment the only solution for pre 2010 owners is to do what Matt did. Using radio controls in the wheel to control the gear changing. Shame it needs a bit of soldering and modding, but does not look too complicated. |
its not a hard job if you can use a soldering iron V8 facelift Range Rover Autobiography 22" wheels.
