![]() | Home > Technical (L322) > Steering wheel reach |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 402 ![]() ![]() ![]() |
There are 2 motors - one for the in/out and one for the up/down. The in/out motor is held on with a white plastic clip that easily breaks and can cause the motor to fall off (whcih looks like what has happened to yours) - You can't get the plastic clip, though i have seen people fabricate something to fix this problem. The other problem with this motor is the black plastic nut can strip its thread - so check that too.
SidewaysMatt Member Since: 25 Feb 2016 Location: Ledsham, Cheshire Posts: 173 ![]() ![]() ![]() |
Mine did the same early last year. As said, you can't get the white plastic mount separately. I used a couple of heavy duty cable ties to lash it back into position, and touch wood, it's been fine since. Is a very uncomfortable job to do though! 2004 Vogue TD6 - Remapped |
RRV78 Member Since: 15 Sep 2016 Location: Truro Posts: 203 ![]() ![]() ![]() |
Is this not the bracket I need?
Well I'll be.....
I was on a well known auction site and happened to see one on there and was showing the land rover part number on the packet so googled it and this was cheapest place I found it. |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
Thats the bracket you need QYH500030 - always been available, although not everyone stocks it. Although these days its a lot more expensive than it used to be - used to only be a fiver!
