![]() | Home > Technical (L322) > 2010 Autobiography, tow tongue fitment? |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
You took the pic with a phone? Ron B. VK2OTC
Grizzly_Adams Member Since: 11 Dec 2017 Location: Brisbane Posts: 36 ![]() ![]() ![]() |
Yup Ron, I even tried rotating it on my PC and when I uploaded the picture it rotated back.. [/quote] |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35841 ![]() ![]() |
pic sorted for you |
Thank you! |
You simply turn the 4 tabs 90 degree's and pull off that panel, when removed you will see the bracket your electrics socket should be fitted to on the left side of the tow bar bracket... |
Thanks Craig - I had recognised the Design pack bodykit but didn't realise it needed to come off before accessing the tow hitch... so not only has this previous owner not known/bothered to do this but they have also moved the electric socket on to the design pack so it can't be easily removed anymore. ![]() Oh well, guess there's a little bit of re-wiring to be done before I can properly prove it works. ![]() I've seen some of your posts and work, very impressive ![]() ![]() Thank you again very very much for the heads up ![]() ![]() ![]() To save me searching around, do you know roughly here the 4 tabs are you speak of? ![]() |
ok, found the tabs.. pretty obvious when you get under the vehicle and look really.
ok got some more photo's now I've taken that underbumper bit off (thanks Craig!)
*sigh*
The centre panel of the bumper also pulls off once you undo the two fixing plastic screw in thingy's!
Drew Member Since: 19 Sep 2012 Location: Brisbane Posts: 3 ![]() ![]() ![]() |
Are there multiple tow hitch assemblies for the different regions? (Eg. UK, US, OZ)
@Drew you're better off starting a new threat, your question will be lost in this one. |
You're better off starting a new threat, your question will get lost in this one ![]() |
Thanks @Grizzly_Adams... will try and figure out how to do that |
