![]() | Home > Technical (L322) > Roof rails |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
Couple of questions please before I go genuine or poweful UK:
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3259 ![]() ![]() ![]() |
I’ve seen gen ones for c.£190 on eBay. The roof caps do have to come off permanently unfortunately. |
or DIY
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
or something like this:
Crispian22 Member Since: 25 May 2017 Location: Midlands Posts: 144 ![]() ![]() ![]() |
I threw a set of genuine ones away a couple of months ago......didnt realise how much they are to buy |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
I have the Whisbar ones and the flaps do not have to come off - good piece of kit
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
If you just want bars rather than rails, then the caps do not have to come off to fit the sports bars, they just flick up to expose the bolts
Thanks all.
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672 ![]() ![]() ![]() |
Don't confuse bars with rails. Sports bars do not remove the plastic covers. Front to back rails I believe do remove the plastic covers as above. |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
If you are fitting front to back rails for which I understand the roof flaps have to be broken off to fit would it be worth considering drilling holes in the said flaps at the fixing bolt positions so that the fixing bolts pass through the flaps to allow the roof rails to sit down flat whilst still retaining the flaps. If you then subsequently remove the rails, the flaps would still be in place, the holes could simply be sealed with gorilla tape or similar patches. Given the flaps are high up any patches would never be seen, if you have a black car even more so. |
or grommets
Even better |
