Home > Wheels & Tyres > Tyre sawtoothing
CMJ
2015 Range Rover Autobiography TDV6 Santorini Black
Tyre sawtoothing
Hi all
I am experiencing excessive tyre noise and when investigated can see both front tyres have sawtooth edging after only 3000 Miles
Front nearside very bad. Can actually see bits of tyre being distorted. .
Now these tyres were brand new, fitted to brand new 22 turbine wheels proceeded by two wheel alignment checks at two different establishments the second of which confirmed all to be in spec except for a small front adjustment which could of been machine related.
Car drives well. No balancing issues. Just noise on approx 80% of road surfaces and some times much quieter on others hence I am not looking for something mechanical and suggest this is tyre related.
Interestingly I also had this issue on the previous set of tyres fitted to the car. Both are contintental tyres however not specific LR endorsed tyres or the premium silent version. However based on the sawtoothing I don’t think a piece of sound deadening in the tyre would solve the noise.
Therefore anyone advise me what mechanic parts to check which may be causing the sawtoothing which would not show up in an alignment check ?
I assume something must be bent to cause this level of issue ? 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #480585 10th Jun 2018 1:11pm
Sandyt
Did you have it 4 wheel aligned on a Hunter system? They tend to be the most accurate by far
Post #480592 10th Jun 2018 2:29pm
Are you sure it's not your driving ?
You could try going around corners a little slower Whistle
Nearside implies you go round a lot of roundabouts......
The 20" Conti's on the L322 were notorious for outer edge wear - but the 22's on the L405 don't seem to suffer. I don't have any experience of the 22's on the L322 though.
Have you had other tyres that fare better ?
Post #480596 10th Jun 2018 2:49pm
CMJ
Hi. Yes to Hunter. We even learnt how to put the car into tight tolerance mode via the brake pedal.
Re traffic islands. My understanding is that if we were to corner too quickly this actually helps with sawtoothing as this smooths the wear off the tyre. 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #480619 10th Jun 2018 6:56pm
An explanation ?
https://www.oponeo.co.uk/tyre-article/saw-tooth-tyre-wear
(robotic voice on video)
https://www.continental-tyres.co.uk/car/te.../lex-1-3-1 .
Post #480631 10th Jun 2018 8:06pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
I had vredstein on 20" on mine when i got it they did that just on the front edge .now got toyo on all 4 no probs so far (not off road tyres tho)
Post #480645 10th Jun 2018 10:05pm
CMJ
Thanks for the input. I have considered (improper inflation, excessive toe-in, low-wear applications and taking into account that I check the pressures and have had the car aligned I am resorting to think it is the kind of tyre combined with lots of moderate style driving however the near side is so acute and as it occurred on the previous set partly owned by the previous owner I hoped there was something else I could check ? Anyone else on 22 continental combination experiencing similar ? 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #480655 11th Jun 2018 5:56am
