Home > Maintenance & Mods (L322) > DPF regeneration
Page 7 of 10 <12345678910>
GGDR
Update from the ramp:
DPF exhaust section out:
...and on the floor:
Inside front face of DPF after cleaning
Didn't get a before pic, sorry.
Looks cleaner to the naked eye than this pic btw.
I do have flow rates before and after:
They are refitting it all now... Cheers, Greg
Post #483875 20th Jul 2018 11:56am
GGDR
Seems sorted.
All errors have been cleared (and not returned)
Greg Cheers, Greg
Post #483895 20th Jul 2018 2:26pm
nino_nino
Post #483897 20th Jul 2018 2:31pm
Baltic Blue
Great news Greg, and now we all know that Soot Mass varies from 0.0g when clean to 31.5g full.👍👍
Post #483898 20th Jul 2018 2:35pm
kgeddes
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
Great result and some useful photos Thumbs Up
I’m just glad I don’t have a dpf fitted.....
Post #483902 20th Jul 2018 3:42pm
GGDR
I think 32.5 is as high as it reads.
The zero I feel may be a slight misnomer.
The reason is that he told the ECU a new DPF was fitted, which is the right thing to do. The flow rate on the ticket he said was excellent, virtually a new DPF rate. That's why the zero came up.
But the ECU was happy and the faults cleared as did the restricted mode.
But it tells me the grams are not exactly a live value and somehow averaged.
It's crept up to 2g in the last hour. Shocked
Slightly worried I'll suffer from DPF anxiety from now on.
Anxiety or not it's fantastic to be driving it again, it's been two weeks. Couldn't get time, between my diary and the DPF guy's diary till now.
. Cheers, Greg
Post #483903 20th Jul 2018 3:43pm
nino_nino
there is sunny side to it to, Greg, it feels like new car all over again. Very Happy i'll bet you're lovin it. Thumbs Up
Post #483904 20th Jul 2018 4:09pm
GGDR
Back in the throne Nino, king of the road again.
Absence makes the heart grow fonder they say.. Cheers, Greg
Post #483910 20th Jul 2018 4:48pm
GGDR
Mike your soot mass has gone down. On page 4 of this thread it was 12.8g
. Cheers, Greg
Post #483916 20th Jul 2018 5:05pm
GGDR
Mike I clarified the sensor question. The sensor error he picked up was the DPF, not the EGR. Slight language barrier but the guy Luka knew his stuff.
The DPF sensor was just crud'd up and fine after the clean.
I still think I should change my sensor now...
. Cheers, Greg
Post #483944 20th Jul 2018 10:19pm
Baltic Blue
I presume that the drop is a result of my long motorway trip. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #483956 21st Jul 2018 8:07am
Baltic Blue
Greg,
Another possible variable for DPF regents .
Yesterday I had to do a quick dash to my daughters, which is a 60 mile M6 trip, but limited to 50mph most of the way due to roadworks.
It was bouncing down the whole journey, but I got my newly trained iPad iid wife to take a few screenshots of the DPF live values.
Cold just out of garage.
After joining motorway
Twenty or so miles later
On arrival
13.5 soot mass is my highest reading ever, and I am blaming, rightly or wrongly the heavy rain for keeping the exhaust cooler than normal ??
Post #488483 9th Sep 2018 11:17am
GGDR
Hi Mike'
All your temps are normal. The 100deg reading we now know thanks to Nino is not a fault but it's the temp sensor post second turbo. You'll find that reads 100 until you call in the cavalry and the spool up the second turbo.
I think your DPF grams will keep creeping up and when it eventually hits 17g, and you're doing 50 mph it'll cook and you'll see the grams drop. It's actually fascinating to watch the readings when it happens. It might take weeks or months to reach 17g (mine is more weeks).
That 17g regen will be the 'passive regeneration' where the DPF spirals up to 600drgrees.
But there may also be a more subtle one although my only evidence is a recent trip to Heathrow, (30mins, 40 & 50mph roads) where I was not near the 17g threshold but before I set off I was at 12.5g and arrived at 11g. I did have the temps visible and didn't see a proper cook going on - i.e. no abnormally high temps showing. Not sure why my grams dropped, they normally go in the other direction.
A more subtle regen happening in the background (loose theory mind) might explain why yours seems to keep itself in check, together with the turbo drain having been done.
. Cheers, Greg
Post #488486 9th Sep 2018 12:25pm
Baltic Blue
Thanks Greg,
I didn’t expect such an increase from 10.8 to 13.5 when it was all over 45-50mph.
I am sure on a dry day it would still read 10 or less on arrival?
Post #488488 9th Sep 2018 12:40pm
Hairy Dan
United Kingdom 2014 Range Rover Vogue SE SDV8 Luxor
Baltic Blue wrote:
I thought I would have a look at the state of my DPF with my IID tool and can't seem to find the settings on my app. Mine is a L405 TDV8 and when I go into Live Values I can't see any of the readings on your IID tool. Did you have to enable something on your app to be able to see these settings or is the L405 different and you can't read those live values?
This is the live value section of my app Confused
 Cheers Ian
Kielder 4x4 Safari
Post #488499 9th Sep 2018 3:43pm
