![]() | Home > Maintenance & Mods (L322) > Fuel Gauge erratic |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3880 ![]() ![]() ![]() |
N.B. Mine is a 2011 4.4tdV8, with 64k on the clock. G reg 2.5VM Vogue Portofino red 1991- 1999
FD Member Since: 15 Jan 2017 Location: Bristol Posts: 31 ![]() |
Nice one, thanks Double_r |
jemj Member Since: 13 Sep 2012 Location: leighton Buzzard Posts: 54 ![]() ![]() ![]() |
Well it looks like I will be doing mine now as it has just packed up. It was reading good and showing that i had just under 100 miles left, I thought that I would fill up tomorrow but when I started it up to nip around to my sons house it read empty. I was hoping that buying a newer model with warranty that I would be spared the constant niggling failures that i have become accustomed to but alas, it is not to be. The Best 4x4 by far, so long as you have deep pockets. |
sniper Member Since: 21 Apr 2019 Location: london Posts: 23 ![]() ![]() ![]() |
Hi folks (i know this is an old thread) my L322 2012 RR Autobiography (with digital dash) reads full fuel (or near full) Fuel level ALL the TIME even after a few hundred miles from full fill up, the lowest it reads is like 1/2-3/4's full... how do i fix ?, im sure its a "stuck sensor" as i haven't used it for like 6 months and left it with a full tank of diesel... please help !! |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 547 ![]() ![]() ![]() |
You could take the inspection plates off and exercise the floats / sensors to see if it makes any difference. You could also measure the resistance across the two sensors and see if one is wildly out. There are threads on here that walk through how to do it. 2016 Skoda Octavia VRS Estate
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561 ![]() ![]() ![]() |
It's here on this thread, just read through from page 1
Soooo, i had a go, for others this may be helpful... you lift up the rear seats, remove the spare wheel cover, remove the rear seat locking brackets (large torx socket screw) remove the trim panels each side (partially, dont need to remove them at the top) then peel the carpet back (tie it to the folded up seats out of the way..)
Well done. |
Swithins Member Since: 22 Oct 2013 Location: West Malling Posts: 151 ![]() ![]() ![]() |
I got caught with this last week in my 08 4.2sc |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 447 ![]() ![]() ![]() |
My car has started reading half what it should do. First indication was today when the low fuel light came on, but reported range of 25 miles (half what it normally does when that happens).
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764 ![]() ![]() ![]() |
Hi John,
Thanks Ash, great info.
Alex5.0 Member Since: 18 Oct 2019 Location: Mainz Posts: 2 ![]() ![]() ![]() |
Hello,
Poprivit Member Since: 11 May 2014 Location: East Yorkshire Posts: 27 ![]() ![]() ![]() |
Had this on mine and it was the connector just as others have said. It’s just a pain to do and you need a low fuel level to do the passenger side. I used a transfer pump and was lucky to have a fairly low level so only needed to pump 20L out. Very poor design but easily sorted. |
