![]() | Home > Technical (L322) > 2003 4.4 petrol struggles to fire when hot. |
| Zambezi Member Since: 07 Feb 2015 Location: Bury St Edmunds, Suffolk Posts: 67
The problem with the LPG not working was traced to the main valve from the LPG tank being seized closed. A new valve has been fitted (which meant the tank had to be emptied to the atmosphere) and that problem is sorted.
| m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 338
When cranking or running - via the fuel pump relay P525
Thanks for confirming that M@ttsFF, so there doesn't seem to be anything wrong with the power getting to the petrol pump.
| All times are GMT |
