Home > Technical (L322) > Towing electrics
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Not an absolute requirement to have brakes. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #487349 28th Aug 2018 11:53am
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
We have them and electric brakes
I have a caravan with electric brakes and a cable hand brake
i think they are magic, they are adjustable from in the cab, so depending how much weight you have, you adjust them to suite
we also have chains from the tow bar to the trailer RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #487350 28th Aug 2018 11:57am
knares
we have to have brakes if the trailer is over 750kl i think it is RR 2005 4.4 petrol
Post #487351 28th Aug 2018 12:00pm
AJGalaxy2012
Correct but not all trailers! BMW i3 Electric Car
Post #487364 28th Aug 2018 3:58pm
All trailers over 750kg or are there exceptions to that ?
No chains In the U.K. - again, IMHO the yank trailers are better
Post #487385 28th Aug 2018 6:57pm
Weegie
Chain in France. John
GAP iiD BT-Sold
Post #487390 28th Aug 2018 7:16pm
knares
Infiltrator how did you go RR 2005 4.4 petrol
Post #500610 5th Jan 2019 1:19pm
Infiltrator
United Kingdom 2010 Range Rover Vogue TDV8 Bonatti Grey
Found the plug after lots of rummaging around. It was really tucked up and had to get my head right down in the wheelwell to see it.
Having the photos of what I was looking for helped massively.
Thanks to everyone for their help.
Project for my day off on Tuesday is to change the front discs and pads. Never tried before, so looking forward to the challenge.
Post #500653 5th Jan 2019 5:01pm
knares
good one
Was there a wiring for the electric brakes?
If I ever get mine going, I will need to have electric brakes RR 2005 4.4 petrol
Post #500718 6th Jan 2019 2:13am
Infiltrator
Not one that I could see, I'm afraid, but then, I'm not the best at this sort of thing....sorry, but there wasn't anything else handing around down there.
Post #500888 7th Jan 2019 9:46pm
Arbuckle
United Kingdom 2012 Range Rover Westminster 4.4 V8 Fuji White
UK wiring does not include a connection for electrically operated brakes as they are not normally used over here.
Maybe the the Australian RR loom is different but doubtful. I would expect the electric brake facility to be installed as a specialist item.
Does the Australian electric braking system use a separate socket?
The UK auxiliary safety electric brake (AL-KO ATC) that operates if the trailer starts to sway excessively gets power from the permanent live supply on 7 or 14 pin plug.. Forty years of progress. 1972-2012
Post #500961 8th Jan 2019 8:55pm
GraemeS
Australia
Electric brake standard wiring in Australia uses pin 5, being one of the UK 2 trailer tail light circuits. This wire has to be cut to prevent the trailer brakes being applied when the tail-lights are on, then a separate electric brake controller wired into the pin 5 wire. Stability control where fitted to a van can be wired to use the power wire in the white socket or a dedicated HD circuit installed.
Post #500963 8th Jan 2019 9:41pm
knares
Haven’t heard of that of that system, sounds interesting
We use a round seven pin plug on our side
thanks RR 2005 4.4 petrol
Post #500979 9th Jan 2019 12:39am
