![]() | Home > Technical (L322) > Towing electrics |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Not an absolute requirement to have brakes. BMW i3 Electric Car
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 825 ![]() ![]() ![]() |
we have to have brakes if the trailer is over 750kl i think it is RR 2005 4.4 petrol
Correct but not all trailers! BMW i3 Electric Car
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8108 ![]() ![]() ![]() |
All trailers over 750kg or are there exceptions to that ?
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3271 ![]() ![]() ![]() |
Chain in France. John
Infiltrator how did you go RR 2005 4.4 petrol
Infiltrator Member Since: 26 Aug 2018 Location: Wiltshire Posts: 13 ![]() ![]() ![]() |
Found the plug after lots of rummaging around. It was really tucked up and had to get my head right down in the wheelwell to see it.
good one
Not one that I could see, I'm afraid, but then, I'm not the best at this sort of thing....sorry, but there wasn't anything else handing around down there. |
Arbuckle Member Since: 11 Nov 2018 Location: Northants Posts: 92 ![]() ![]() ![]() |
UK wiring does not include a connection for electrically operated brakes as they are not normally used over here.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2745 ![]() ![]() |
Electric brake standard wiring in Australia uses pin 5, being one of the UK 2 trailer tail light circuits. This wire has to be cut to prevent the trailer brakes being applied when the tail-lights are on, then a separate electric brake controller wired into the pin 5 wire. Stability control where fitted to a van can be wired to use the power wire in the white socket or a dedicated HD circuit installed. |
The UK auxiliary safety electric brake (AL-KO ATC) that operates if the trailer starts to sway excessively gets power from the permanent live supply on 7 or 14 pin plug..
