Home > General > What Did You Do In Your Full Fat Today |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
Engine oil & filter changed. Transmission flushed by pumping out dark grey fluid out of the cooler line. Fresh oil in the old fashioned way. Very time consuming and awkward. Diffs and transfer box oils changed. Quick test drive with a smug grin and all is wonderful.
7th Oct 2018 10:08pm |
Dizzy Dee Member Since: 26 Dec 2017 Location: London Ish Posts: 96 |
Took it in to have the head gasket changed as it had blown.
10th Oct 2018 6:32am |
Hairy Dan Member Since: 22 Jul 2017 Location: NW Durham Posts: 177 |
Took the space saver spare wheel out to fit a full sized alloy I bought from Ebay. Got the space saver out fine and then used my newly purchased spare wheel 'winch' strap to lift the bloody heavy spare wheel in. Then realised the boot floor wouldn't sit flat so had to take the spare out again and remove the grey polystyrene ring and then lift the spare back in again How anybody could get the spare wheel out without one of these lifting straps is beyond me although, I suppose mine didn't have one as it was originally specced with a space saver
14th Oct 2018 3:57pm |
Took it for a service Glad to report no extra work needed although on the MOT earlier this year the tester reported that the pads were just about worn out and the discs were badly worn, so I was expecting 'the phone call'. when I picked the car up just now they said the pads had about 50% life left in them and the discs are fine I wonder if the last main dealer was touting for some work? Cheers Ian
16th Oct 2018 5:03pm |
New rear discs and pads. Had handbrake shoes, pins and springs to fit too but when inspected they were virtually new. It had recent back plates too. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
16th Oct 2018 9:41pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Done it so many times .... you need to be in the boot - not stood outside Land Rover Addict XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
16th Oct 2018 9:45pm |
I know what you mean - when you can do 45,000 miles on a set and then be told 5,000 miles after fitting a new set that 'they're worn and need replacing.....' - yeah that. Land Rover Addict XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
16th Oct 2018 9:47pm |
nearlee Member Since: 28 Feb 2018 Location: Where the sheep are scared Posts: 245 |
Made a mess of it
20th Oct 2018 10:25pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3687 |
Have you any idea how long it took me to clean those wheels,
21st Oct 2018 8:43am |
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 |
Headlight polishing day.
21st Oct 2018 4:54pm |
Thats good that, What product did you use please? |
21st Oct 2018 7:47pm |
I used Meguiars Heavy Duty Headlight restoration kit.
21st Oct 2018 7:55pm |
Thank you |
21st Oct 2018 8:51pm |
mark35gun Member Since: 01 Oct 2018 Location: swanwick Posts: 63 |
changed the oil and filter finally sussed out the bovee wma1000 thanks to Cass 2011 4.4 tdv8 autobiography black
22nd Oct 2018 8:26pm |
