![]() | Home > General > What happens when you pull this !!!!! |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
oh no... you should not have pulled that wire loop.. 2004 black Vogue TD6 |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
Releases the locking solenoid I do beleive, in case of a battery failure. 2006 Mercedes CLS
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Inflatable life raft? Should you end up in water...... |
but wont the boot be locked vai a solenoid too? 2004 black Vogue TD6 |
![]() parachute? should you fall off a cliff.. 2004 black Vogue TD6 |
Grenade ring? Pull pin and throw car?!?
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
1 ...... 2........ 3......... |
Maybe it's a critical linchpin, that holds the whole car togeather?....... |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
The optional rear ejector seat? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
L7APK Member Since: 14 Jan 2011 Location: Lancashire Posts: 25 ![]() ![]() ![]() |
Thank god for that, and heres me thinking it was something important. |
Which model do you have L7? Could be the misfuel device reset on a TDv8 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
On mine, (not sure about later models) you can release the upper tailgate from inside using the small black plastic pull if your battery goes flat, like mine did when I came back off holiday to find 2 flat tyres and a flat battery ![]() 1991 Retro-style Mini But really finding it hard to fight the urge for a S/C... |
OK, just found out what it does,
is that it, boring.... |
