Home > General > What happens when you pull this !!!!! |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 |
oh no... you should not have pulled that wire loop.. 2004 black Vogue TD6 |
9th Feb 2011 11:54pm |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
Releases the locking solenoid I do beleive, in case of a battery failure. 2006 Mercedes CLS
10th Feb 2011 12:25am |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
Inflatable life raft? Should you end up in water...... |
10th Feb 2011 12:26am |
but wont the boot be locked vai a solenoid too? 2004 black Vogue TD6 |
10th Feb 2011 12:51am |
parachute? should you fall off a cliff.. 2004 black Vogue TD6 |
10th Feb 2011 12:56am |
Grenade ring? Pull pin and throw car?!?
10th Feb 2011 1:12am |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
1 ...... 2........ 3......... 2010 Disco XS TDV6, 2009 Freelander 2 GS
10th Feb 2011 4:45am |
Maybe it's a critical linchpin, that holds the whole car togeather?....... |
10th Feb 2011 5:13am |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 |
The optional rear ejector seat? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
10th Feb 2011 9:31am |
L7APK Member Since: 14 Jan 2011 Location: Lancashire Posts: 25 |
Thank god for that, and heres me thinking it was something important.
10th Feb 2011 8:06pm |
Which model do you have L7? Could be the misfuel device reset on a TDv8 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
10th Feb 2011 8:13pm |
On mine, (not sure about later models) you can release the upper tailgate from inside using the small black plastic pull if your battery goes flat, like mine did when I came back off holiday to find 2 flat tyres and a flat battery 2006 Mercedes CLS 1991 Retro-style Mini But really finding it hard to fight the urge for a S/C... |
11th Feb 2011 12:06am |
OK, just found out what it does,
11th Feb 2011 3:55pm |
is that it, boring....
11th Feb 2011 4:30pm |
