Home > General > What happens when you pull this !!!!!
L7APK
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Behind the off side panel in the boot, theres the green plastic tab for opening the fuel filler in an emergency. Also theres a metal wire loop, that sort of protrudes where the wheel arch is, in the same area. Does anyone know what its for, tried pulling it and nothing clicked open Confused
Post #49532 9th Feb 2011 11:48pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
oh no... you should not have pulled that wire loop.. 2004 black Vogue TD6
Post #49534 9th Feb 2011 11:54pm
M44K TS
Releases the locking solenoid I do beleive, in case of a battery failure. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #49544 10th Feb 2011 12:25am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Inflatable life raft? Should you end up in water......
Post #49545 10th Feb 2011 12:26am
letsavit2
but wont the boot be locked vai a solenoid too? 2004 black Vogue TD6
Post #49551 10th Feb 2011 12:51am
letsavit2
Laughing
parachute? should you fall off a cliff.. 2004 black Vogue TD6
Post #49553 10th Feb 2011 12:56am
Richcl
Grenade ring? Pull pin and throw car?!?
(Getting silly now! Laughing )
Post #49554 10th Feb 2011 1:12am
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
1 ...... 2........ 3......... Censored 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #49558 10th Feb 2011 4:45am
Richcl
Maybe it's a critical linchpin, that holds the whole car togeather?....... Shocked
Post #49559 10th Feb 2011 5:13am
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
The optional rear ejector seat? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #49560 10th Feb 2011 9:31am
L7APK
Thank god for that, and heres me thinking it was something important. Laughing
But seriously, what is it?
Post #49624 10th Feb 2011 8:06pm
Tim in Scotland
Which model do you have L7? Could be the misfuel device reset on a TDv8 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #49625 10th Feb 2011 8:13pm
M44K TS
On mine, (not sure about later models) you can release the upper tailgate from inside using the small black plastic pull if your battery goes flat, like mine did when I came back off holiday to find 2 flat tyres and a flat battery Sad 2006 Mercedes CLS
Post #49664 11th Feb 2011 12:06am
L7APK
OK, just found out what it does,
its the emergency electronic handbrake release. Wink
Post #49728 11th Feb 2011 3:55pm
letsavit2
is that it, boring.... Laughing
Wink 2004 black Vogue TD6
Post #49737 11th Feb 2011 4:30pm
