![]() | Home > Technical (L322) > Found loose plug what could that be? |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I cant see the plug, there is an auxiliary water pump on the inner wing over that side you could look at |
KMMJE Member Since: 05 Mar 2017 Location: Vienna Posts: 6 ![]() ![]() ![]() |
Thanks, I checked the area...thats where the cable comes from and leads towards the back of the car....I just flipped the plug over so it would be better visible in the Picture...
I will check mine. it may be something to do with the Fuel Burning Heater that probably isn't fitted to yours. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
could be for the diesel cooling fan. which may not be fitted in your region. There is nothing that can't be fixed with a hammer😜😜
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1582 ![]() ![]() |
If you note the colours of the wires, it's fairy easy to identify circuits by looking at the circuit diagram. Ron B. VK2OTC
