Home > Technical (L322) > Found loose plug what could that be?
KMMJE
Austria 2003 Range Rover Vogue 4.4 V8 Java Black
Hi guys,
as a RR newbie I need your help, I found a loose plug on the right side of the engine and I cant figure out where it belongs to.
It has two wires, one white/black and one brown/black. The plug looks very clean so I think it must have been connected to something. I only have a basic OBD tool which told me that the purge valve has an error, beside that the RR only shows shows that the air supspension is inop.
Any ideas?
thanks
Kevin
Post #496046 20th Nov 2018 11:32am
holidaychicken
I cant see the plug, there is an auxiliary water pump on the inner wing over that side you could look at
Post #496129 20th Nov 2018 10:09pm
KMMJE
Thanks, I checked the area...thats where the cable comes from and leads towards the back of the car....I just flipped the plug over so it would be better visible in the Picture...
still no clue Question Shocked
Post #496389 23rd Nov 2018 3:41pm
holidaychicken
I will check mine. it may be something to do with the Fuel Burning Heater that probably isn't fitted to yours.
Post #496418 23rd Nov 2018 6:18pm
could be for the diesel cooling fan. which may not be fitted in your region. There is nothing that can't be fixed with a hammer😜😜
Post #496423 23rd Nov 2018 6:38pm
p38arover
Australia
If you note the colours of the wires, it's fairy easy to identify circuits by looking at the circuit diagram. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #496453 23rd Nov 2018 10:09pm
