![]() | Home > Maintenance & Mods (L322) > Possible to deactivate/disable LED halo angel eyes? |
Woofster Member Since: 12 Jul 2018 Location: Toronto Posts: 121 ![]() ![]() |
On mine, the inner halogen H7 bulbs are my Daytime Running Lights (DRL) and are on when the light switch is in the 0 (exterior lamps off) setting. All other exterior lights are off.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35851 ![]() ![]() |
you might have an aftermarket drl switch fitted for the halogens [main beam] to come on when the engine is running and the light switch is off...
Pictures of the plugs as promised sir... you will see there are two plugs with just black wires that go to the two separate rings in your lights... Easily pulled off with long nosed pliers... |
Cam-Tech-Craig, you are a gentleman and a scholar. I still haven't had a chance to pop my head under the hood of the 2010 to go searching for wires so these photos are super helpful (kind of like a road map before a road trip!). 2010 RR SC
Update: So I had some time to remove one of my headlight assemblies this afternoon. Using Craig's photo above as reference, I peered inside the housing, only to come to realize...that it is extremely cramped in there! It was quite difficult trying to locate/trace wires through the few small openings that are available.
Pic no 2 shows the plug for the smaller ring around the halogen light... If you click on it, it will allow you to zoom in...
Would you recommend going through the larger opening of the Xenon light to access the connector around the halogen light? Frustratingly I don't feel there is much access or clearance to anything at all through the smaller opening of the halogen light. 2010 RR SC
Just another thought, Craig, what do you think about simply cutting the wire going into either pin 1 or pin 4 (associated with the side lights and halos) at the 16-pin loom? 2010 RR SC
Not a fan of cutting wires! |
Mission accomplished! The LED angel eye halo lights that go around each of the 4 front headlights are now deactivated. A big thank you to the helpful and passionate RR members of this forum! 2010 RR SC
so now what happens when you put your side lights on ? |
So here are how my lights are now operating. Keep in mind I am in Canada and my DRLs had been previously set up a certain way where the halo lights were never used as DRLs in the first place (by the previous owner).
Stan, don't forget the OP is in Canada and they run 24hrs a day 22w DRL's... Meaning the high beam halogens are illuminated to 40% brightness...
