Home > Technical (L405) > Erratic side step behaviour
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
Thank you, I will give this a try. Assume your lubricating the hinges/moving parts?
Looks like the motor is sealed in.
Post #499296 21st Dec 2018 6:59am
Yes exactly, all the points where a spindle turns in a bracket - there's loads of them! Mike - MPx
Post #499309 21st Dec 2018 10:10am
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Software update: If they did one it has made no difference - suspect I will be underneath it tomorrow lubricating the mechanism!
White grease favourite from a spray can I guess.... 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #499357 21st Dec 2018 6:20pm
C-T-C says he uses white grease...I use 3in1 High Performance Lubricant with PTFE which I stumbled across by accident, but seems to work well and for much longer than other stuff I've tried. Mike - MPx
Post #499358 21st Dec 2018 6:31pm
Charles89
Quick update, this now works perfectly following a heavy lubing. Now have an issue of the car locking the passenger in Mad one thing after another sometimes
Post #502067 19th Jan 2019 8:10am
GGDR
For every moment of joy these things will keep you busy, that's for sure.
Totally worth it.
. Cheers, Greg
Post #502072 19th Jan 2019 8:43am
fin
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
Alright gents,
My passenger one has started to be stuck out when i walk up to it parked i notice it, and sometimes when i'm driving and when i've not even opened the passenger door. I've opened and closed the passenger door and it went back in, now it starts to go back in, senses something i would guess and then comes back out, however if i open the door and then when it starts to go back in help along with my foot also it goes in and stays in.
Do we have photos or what should be cleaned and oiled/lubed?
Post #571865 4th Nov 2020 5:50pm
TJH1985
Our drivers one has also started to play up a little over the last few day’s, a good soaking in penetrating moisture dispersal oil followed by some white lithium grease and they are smooth as silk once again!
This really should be a service item, my caravan comes back covered in white grease on basically anything that moves but LR techs pretty much just change the oil Rolling Eyes Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #578245 3rd Jan 2021 3:45pm
I'm sure they would grease them if you asked.....and of course they would charge you silly money for doing the job... ... - .- -.
Post #578246 3rd Jan 2021 3:49pm
