Home > Technical (L405) > Erratic side step behaviour |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 527 |
Yes exactly, all the points where a spindle turns in a bracket - there's loads of them! Mike - MPx
21st Dec 2018 10:10am |
160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 452 |
Software update: If they did one it has made no difference - suspect I will be underneath it tomorrow lubricating the mechanism!
21st Dec 2018 6:20pm |
C-T-C says he uses white grease...I use 3in1 High Performance Lubricant with PTFE which I stumbled across by accident, but seems to work well and for much longer than other stuff I've tried. Mike - MPx
21st Dec 2018 6:31pm |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 |
Quick update, this now works perfectly following a heavy lubing. Now have an issue of the car locking the passenger in one thing after another sometimes |
19th Jan 2019 8:10am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
For every moment of joy these things will keep you busy, that's for sure. Totally worth it. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
19th Jan 2019 8:43am |
fin Member Since: 20 Oct 2010 Location: South East London Posts: 50 |
Alright gents,
4th Nov 2020 5:50pm |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 663 |
Our drivers one has also started to play up a little over the last few day’s, a good soaking in penetrating moisture dispersal oil followed by some white lithium grease and they are smooth as silk once again!
3rd Jan 2021 3:45pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
I'm sure they would grease them if you asked.....and of course they would charge you silly money for doing the job... ... - .- -.
3rd Jan 2021 3:49pm |
