![]() | Home > Technical (L322) > Another noob question of parking heater and pre heater |
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 ![]() ![]() |
In my experience on a frosty morning with ice on the windscreen the FBH needs at least 15 min to make a useful difference and melt the ice. 20 -25 min better yet. I think it shuts off automatically after 30 min. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7996 ![]() ![]() ![]() |
The heater will run for a max of 30 minutes, so I aim to get to the car at about 25 mins.
Lester Burnham Member Since: 12 Sep 2018 Location: North Posts: 116 ![]() ![]() |
Cheers I'll have to remember to switch the FBH on before making my sandwiches!
You should be able to manually turn the FBH on before you leave someone in the car and use that for warmth if you need to.
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
the residual heat only blows air through the heater matrix after 2mins or so its cold anyway.
Cheers both, do you use the menu (2010 0n) or just plip the little remote again? |
Devilish Member Since: 08 Jan 2019 Location: Staffordshire Posts: 4 ![]() ![]() |
The FBH runs a self test during start up, anything wrong with the FBH, then it will purge the combustion chamber for 2 mins, then shut off. If it fails to start 3 times in a row, the PCB locks out the starting sequence, pulling the fuse for a spell can reset the lockout, but it does not cure what caused the lockout. If the FBH starts up ok, it can take about 2 minutes for it to ramp up to full speed. As previously said, hard for it to run hot for 2 mins when it takes longer than that to start up. |
Thanks for that info, sorry not to acknowledge, just seen this been too busy for the internet for a few weeks.
