Home > Technical (L322) > Another noob question of parking heater and pre heater |
Nick591 Member Since: 04 May 2017 Location: Charfield Posts: 193 |
In my experience on a frosty morning with ice on the windscreen the FBH needs at least 15 min to make a useful difference and melt the ice. 20 -25 min better yet. I think it shuts off automatically after 30 min. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
23rd Dec 2018 11:10am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7635 |
The heater will run for a max of 30 minutes, so I aim to get to the car at about 25 mins.
23rd Dec 2018 12:12pm |
Lester Burnham Member Since: 12 Sep 2018 Location: North Posts: 116 |
Cheers I'll have to remember to switch the FBH on before making my sandwiches!
23rd Dec 2018 1:34pm |
You should be able to manually turn the FBH on before you leave someone in the car and use that for warmth if you need to.
23rd Dec 2018 1:39pm |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 428 |
the residual heat only blows air through the heater matrix after 2mins or so its cold anyway.
23rd Dec 2018 8:03pm |
Cheers both, do you use the menu (2010 0n) or just plip the little remote again? |
24th Dec 2018 6:53pm |
Devilish Member Since: 08 Jan 2019 Location: Staffordshire Posts: 4 |
The FBH runs a self test during start up, anything wrong with the FBH, then it will purge the combustion chamber for 2 mins, then shut off. If it fails to start 3 times in a row, the PCB locks out the starting sequence, pulling the fuse for a spell can reset the lockout, but it does not cure what caused the lockout. If the FBH starts up ok, it can take about 2 minutes for it to ramp up to full speed. As previously said, hard for it to run hot for 2 mins when it takes longer than that to start up. |
8th Jan 2019 11:32pm |
Thanks for that info, sorry not to acknowledge, just seen this been too busy for the internet for a few weeks.
14th Jan 2019 5:30pm |
