Home > My Range Rover > range rover with problems
Page 12 of 18 <123 ... 111213 ... 161718>
holidaychicken
You did speak too soon!
Did you use the cam covers with doubled up washers to force the upper timing covers down and to compress the seal between the upper and lower timing covers ? That part is in the beisan procedure.
Post #499626 25th Dec 2018 3:18am
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
yes, i did that
its ok that way
the housing needs to go to the left RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #499645 25th Dec 2018 2:55pm
holidaychicken
The lower timing chain cover lines up on dowel / roll pins and the upper timing cover should line up with the lower timing cover.
Post #499671 25th Dec 2018 11:30pm
knares
hi again
i took the cover off again, refitted it but before i tightened it home, i fitted the seal and then tightened it down.
i think its a better fit now than the other side.
i went to fit the oil pick up pipe/strainer and wasn't very happy with it so i made a broach and pressed up a new screen.
so the sump plate is on.
its pretty hot over here, up to 42 some days, i used to love the heat but now it just saps me, so i hide inside some times, not getting much done.
bought the oil to day, Castrol Edge 5W-30 on special 50%discunt
 RR 2005 4.4 petrol
Post #504667 10th Feb 2019 8:32am
holidaychicken
Good news, you will get there.
The oil pickup screen looks good, did you say you made that ?
Post #504714 10th Feb 2019 3:34pm
knares
yes, i machined up a couple of pieces of steel, put them in the press and it came out fine
i didnt make the mesh, i just made the mesh fit RR 2005 4.4 petrol
Post #504772 11th Feb 2019 12:21am
holidaychicken
Looks good Thumbs Up
Post #504774 11th Feb 2019 12:30am
knares
thanks RR 2005 4.4 petrol
Post #504777 11th Feb 2019 5:07am
knares
when i took the injector wires off the injectors, the clips are very difficult to remove and one of them was missing
these clips, apparently, are not sold as a spare part RR 2005 4.4 petrol
Post #506807 1st Mar 2019 11:02am
holidaychicken
The clips are not sold separately, and they need to be there but you may be able to pick up a connector off of something else as they will be a standard.
The way I get mine off and on is to place your hands either end of the black plastic injector wiring box and with a 1,2,3 yank, they all come off together . To put back on I make sure they are all lined up and give them a sharp push and they all pop back on . Has always worked for me. With one wire clip missing you will probably be ok but better to have it .
Not saying this is the one but google injector connector and then just pinch the wire clip off it
https://m.ebay.co.uk/itm/Fuel-Injector-BOS...noapp=true
Post #506942 2nd Mar 2019 3:10am
knares
I got a clip, BMW came to the rescue
I gave it a crank and it started immediately, oil pressure 50+
Only ran it for a couple of seconds, no water
New radiator should be here end of the week then I will be able to run it properly
At long last RR 2005 4.4 petrol
Post #506967 2nd Mar 2019 11:41am
holidaychicken
Good work, Coolant is the green / blue type rather than the pink, how much difference that makes I'm not sure but i have always run Motul INUGEL EXPERT ULTRA Concentrated Antifreeze in mine.
That must feel good to be wear your are at last.
I would expect some rattles as it starts to fill up the various hydraulic units
Post #507189 3rd Mar 2019 7:51pm
knares
"I would expect some rattles as it starts to fill up the various hydraulic units"
its about eighteen month since i pulled the engine down so things would be pretty dry.
so i filled the sump with oil through the hole where the oil pressure switch fits and i primed the oil pump from the oil filter pipe RR 2005 4.4 petrol
Post #507241 4th Mar 2019 1:00am
knares
had a look at that on the net $20lt mix 50/50 RR 2005 4.4 petrol
Post #507355 4th Mar 2019 8:45pm
knares
Early on in the piece I read Haylands post about thermostats, I decided to go for the BMW one.
I also read, it was a good idea to change the radiator pressure cap to 140kpa
Mine had a 200
I bought one on ebay, I then read that the ones on ebay weren’t reliable as far as the pressure was concerned.
I made up a fitting to test the 140kpa rad cap, it cracks at 160kpa
My radiator arrived on Friday but no one was home, so now its Monday
I ordered a thermostat on ebay, I put the BMW part number in, up came a thermostat and I purchased it, now I think I have ordered the wrong one RR 2005 4.4 petrol
Post #508145 10th Mar 2019 6:09am
