![]() | Home > My Range Rover > range rover with problems |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 834 ![]() ![]() ![]() |
yes, i did that
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
The lower timing chain cover lines up on dowel / roll pins and the upper timing cover should line up with the lower timing cover.
hi again
Good news, you will get there.
yes, i machined up a couple of pieces of steel, put them in the press and it came out fine
Looks good |
thanks RR 2005 4.4 petrol
The clips are not sold separately, and they need to be there but you may be able to pick up a connector off of something else as they will be a standard.
I got a clip, BMW came to the rescue
Good work, Coolant is the green / blue type rather than the pink, how much difference that makes I'm not sure but i have always run Motul INUGEL EXPERT ULTRA Concentrated Antifreeze in mine.
"I would expect some rattles as it starts to fill up the various hydraulic units"
Early on in the piece I read Haylands post about thermostats, I decided to go for the BMW one.
