![]() | Home > Technical (L405) > L405 "design faults"? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
Front fogs deliver a wide short beam pattern, which, being low, helps you to see the kerbs/edge of road in foggy conditions. They are not particularly designed to help others see you. The rears do that, and I always turn my rears off when a car comes behind me in fog, as obviously they have seen me.
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
Map reading lights in the rear are easy to turn on accidentally and then keep coming on every time the ignition is turned on (but there is no way to turn them off from the driver's seat |
CJB1000 Member Since: 22 Jul 2017 Location: Yorkshire Posts: 31 ![]() ![]() ![]() |
Just a few to be going on with.....
I couldn't stand the mats not fitting either so i bought these... |
Sounds like knocking the car here but not at all, it's brilliant... there are wee things you always notice though:
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2626 ![]() ![]() |
The driver’s side genuine rubber mat is rubbish too. |
The Renault Captur and the later Ford Fiesta has a little round gripper that fits in the small centre hole and stops the cup holders pulling out ![]() These also work on a 322 & a D4 https://www.ebay.co.uk/itm/GENUINE-FORD-FI...:rk:4:pf:0 https://www.google.co.uk/search?q=renault+...ybtGAitCM: |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
The fridge is a PIA to get to and I miss the sunglasses holder from the L322, but other than that I think generally they have done a decent job |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
That’s a good point about the fridge and why doesn’t the top fold back to 180 degrees to get completely out of the way of the driver’s elbow and then fold down flat to form a handy tray for rear seat passengers, just as used to in the D4? |
AndyS Member Since: 27 Feb 2016 Location: Lymington, Hampshire Posts: 419 ![]() ![]() |
It could also helpfully slide forward to make a more comfortable armrest rather than the skinny thing which I find uncomfortable.
Where did you get those? |
Its a swear word i know but they are manufactured by Britpart |
Thank you |
