Home > In Car Electronics (L322) > Streaming Music From My iPhone 6s to my L322 |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3641 |
Mine doesn't seem to charge, but I can move forward and backward through my Spotify playlists. Geoff |
7th Jan 2019 5:43pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2598 |
Goes into the genuine Land Rover cable which has a connector in the cubby box |
8th Jan 2019 10:30pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34917 |
@carl, the LR ipod 30 pin connector will only work on the 2010-2012 years.. |
8th Jan 2019 10:35pm |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 326 |
If you have the SC you should have the aux socket - I use a Bluetooth device connected through this .. 4.4 AdBlu Tractor
8th Jan 2019 11:06pm |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 |
don't know anything about audio stuff but car looks good with dark roof and wheels |
8th Jan 2019 11:59pm |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
Can the Bovee be used to stream 'waze' app for sat nav like on the Audi. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
9th Jan 2019 1:35am |
Carl 40BMI RRSC Member Since: 02 Jan 2019 Location: Coventry Posts: 8 |
i have a phone connection in the cubby box is that what you mean? Or is it something different? I do have an Aux socket in the rear but didn’t want a cable coming from the back if I could help it. |
9th Jan 2019 7:00am |
The only non surgical way on you model year is as Stan said the aux in socket in the back and a Bluetooth dongle on the end, then tuck them into the cubby and you don’t se it. The other way is the LR iPod kit, but these are expensive and require some disassembly of the dash for fitting. Check in the front glove boxes to see if you have something fitted. There may be something a previous owner has done.
15th Jan 2019 8:55am |
RangeRover313 Member Since: 09 Dec 2018 Location: NRW Posts: 1 |
Ive got a 30 pin to lightning adaPter.. no reaction
8th Feb 2019 11:21pm |
Well after extensive testing I can confirm that the non genuine 30pin adapter doesn't work and I have been listening to downloaded Spotify playlists for the last few weeks with no problem using the genuine lead - no need for Bovee which is a shame because I wanted to mess about with one.
9th Feb 2019 3:37pm |
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 528 |
I've just picked up my 2010 model SC AB today (very nice!) and need to get the sounds sorted. Amazing that JLR didn't incorporate Bluetooth playback in a car like this, but hey.
9th Feb 2019 3:53pm |
this does BT streaming ,
9th Feb 2019 3:59pm |
Hmm, I was trying to avoid adding too much extra hardware Stan, as I understand it the Bovee option is basically a Bluetooth dongle which you "lose" in the cubby? |
9th Feb 2019 4:09pm |
Well, I bought a used cable from eBay which works, but doesn't charge. This is plugged into an old iPhone 4 with no SIM, just using it as an iPod or hotspotting off my iPhone 8 for Spotify, so no Apple adaptor lead involved as the iPhone 4 has the old style connector. Should it be charging? I'm wondering now whether the cable is a genuine JLR item; I thought it was. |
15th Feb 2019 12:04pm |
