![]() | Home > In Car Electronics (L322) > Streaming Music From My iPhone 6s to my L322 |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3949 ![]() ![]() ![]() |
Mine doesn't seem to charge, but I can move forward and backward through my Spotify playlists. Geoff |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2718 ![]() ![]() ![]() |
Goes into the genuine Land Rover cable which has a connector in the cubby box |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35832 ![]() ![]() |
@carl, the LR ipod 30 pin connector will only work on the 2010-2012 years.. |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 337 ![]() ![]() ![]() |
If you have the SC you should have the aux socket - I use a Bluetooth device connected through this .. P525
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
don't know anything about audio stuff but car looks good with dark roof and wheels |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Can the Bovee be used to stream 'waze' app for sat nav like on the Audi. |
Carl 40BMI RRSC Member Since: 02 Jan 2019 Location: Coventry Posts: 8 ![]() ![]() ![]() |
i have a phone connection in the cubby box is that what you mean? Or is it something different? I do have an Aux socket in the rear but didn’t want a cable coming from the back if I could help it. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
The only non surgical way on you model year is as Stan said the aux in socket in the back and a Bluetooth dongle on the end, then tuck them into the cubby and you don’t se it. The other way is the LR iPod kit, but these are expensive and require some disassembly of the dash for fitting. Check in the front glove boxes to see if you have something fitted. There may be something a previous owner has done.
RangeRover313 Member Since: 09 Dec 2018 Location: NRW Posts: 1 ![]() ![]() ![]() |
Ive got a 30 pin to lightning adaPter.. no reaction |
Well after extensive testing I can confirm that the non genuine 30pin adapter doesn't work and I have been listening to downloaded Spotify playlists for the last few weeks with no problem using the genuine lead - no need for Bovee which is a shame because I wanted to mess about with one.
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 ![]() ![]() |
I've just picked up my 2010 model SC AB today (very nice!) and need to get the sounds sorted. Amazing that JLR didn't incorporate Bluetooth playback in a car like this, but hey.
this does BT streaming ,
Hmm, I was trying to avoid adding too much extra hardware Stan, as I understand it the Bovee option is basically a Bluetooth dongle which you "lose" in the cubby? |
Well, I bought a used cable from eBay which works, but doesn't charge. This is plugged into an old iPhone 4 with no SIM, just using it as an iPod or hotspotting off my iPhone 8 for Spotify, so no Apple adaptor lead involved as the iPhone 4 has the old style connector. Should it be charging? I'm wondering now whether the cable is a genuine JLR item; I thought it was. |
