Home > Maintenance & Mods (L322) > ZF 8 speed gearbox megaflush
Page 2 of 3 <123>
Mikey
Oil has to cool from 90-ish degrees down to between 45-50
In the workshop, on a ramp, its around 4 hours to cool down sufficiently, reading the live temperatures via Autologic, and it warms up again pretty quick Laughing
Post #501720 15th Jan 2019 8:37pm
Ok, that makes sense Thumbs Up
Mine took a good hour to get up past 50 degrees but it was rather cold here yesterday evening... Rolling Eyes
Post #501727 15th Jan 2019 9:21pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
I had a drain, fill, new filter and sump yesterday as it happens as a hopefully proactive and preventative measure on my 5.0 S/C, while my truck was in with Brownchurch for it's MOT!
It has only done 72k miles, but I thought the ZF recommendation was 75k which I will pass in the next few months. Thankfully the MOT was all clear with no advisories, so still a relatively cheap visit to the garage Smile.
Post #501734 15th Jan 2019 9:53pm
DrRob
Paul - rough cost for that drain and refill ? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #501768 16th Jan 2019 8:34am
I did mine a month or so back, pretty easy, got a pan off AUTODOC (something like £65 for a ZF one) and £19/l for gen ZF oil from my tyres.co.uk so cheaper DIY with gen stuff works out at about £190👍🏻 There is nothing that can't be fixed with a hammer😜😜
Post #501769 16th Jan 2019 8:42am
GraemeS
Australia
How much oil gets changed when the pan is dropped? I recently only collected 3L by draining the pan but intend replacing the pan c/w filter next time.
Post #501777 16th Jan 2019 10:48am
paulbrown22
Afraid I was lazy with this one as the car was at the garage anyway!
ZF Lifeguard oil/filter/metal sump were ~£300. Oil price was the same as northernmonkeyjones, but I definitely paid more for the sump/filter.
Labour ~£250.
Post #501778 16th Jan 2019 10:50am
GGDR
I've searched all the threads and expect to drop 5 litres removing the pan.
As full flushing is difficult/specialist, I've bought 10 litres and plan to do two oil changes with a good run in between. New pan on the first change.
. Cheers, Greg
Post #501779 16th Jan 2019 10:54am
GraemeS
Australia
Post #501785 16th Jan 2019 12:43pm
Expect about 5 litres, plan to get 6/7 so you have enough to put back in. I think where folks hanvent had that much out the thermostat must have been shut. There is nothing that can't be fixed with a hammer😜😜
Post #501797 16th Jan 2019 3:21pm
Mikey
Your only draining the sump, not the pipework too Thumbs Up
And expect somewhere around 4 litres to drain out
Post #501799 16th Jan 2019 3:40pm
DrRob
Mikey
How does the Megaflush bypass the thermo valve? I assume with some clever bit of plumbing used for the process? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #501802 16th Jan 2019 4:45pm
bruno22rf
England 2004 Range Rover Vogue 4.4 V8 Java Black
I think my local specialist charges £260 all in for a mega flush - is that a good price?
Post #502008 18th Jan 2019 4:50pm
nino_nino
ZF in Germany charges 620 Euros for a flush 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #502027 18th Jan 2019 6:56pm
DrRob
With decent oil? With a Megaflush machine? Then yes Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #502031 18th Jan 2019 7:12pm
Page 2 of 3 <123>
