Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A ***
Page 39 of 47 <123 ... 383940 ... 454647>
this video by powerfuluk might help setting up yours Wink ,
Post #501737 15th Jan 2019 9:59pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
Yes, firmware updates free via a programme you can download to your computer which will handle updating the IIDTool itself. Up to you how often you do it I guess - I took a few updates when Patrick was testing out something for me, but I've left it alone since then just because it did everything I needed so far.
Digital dash speed readout was one of my first things too - just make sure you have a full battery and/or a decent charger connected before you start doing too much with the CCF especially, as the vehicle battery doesn't last long when you start playing with your IIDTool!
Post #501738 15th Jan 2019 9:59pm
i recommend having the engine running when playing with your tool...
Post #501740 15th Jan 2019 10:03pm
DrRob
Cheers Thumbs Up 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90 on order so "Rory" will be going to a new home....!
Post #501742 15th Jan 2019 10:05pm
rar110
Correct. Log in ti GAP on a PC or Mac, plug the IID tool in with the USB cable and download the latest update from GAP. I probably do this a couple of time per year. ______________________________
Post #501744 15th Jan 2019 10:14pm
DrRob
2011 car. What DRL options are there that can be enabled and a pointer to which menu? 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #501789 16th Jan 2019 1:38pm
Baltic Blue
Rob,
I activated DRL’s on my 2011 a couple of months ago, but from memory it’s in .. Live values...Untested values.
Be aware that you will loose what I will call menu set options, ie... clock/date settings. Forward alert, speed warnings settings etc. They will all need resetting on completion. Also for some reason or other I lost the mirrors auto folding on locking setting, which Craig told me how to reset. All simple to reset, but a pain.
Post #501807 16th Jan 2019 5:14pm
Andy
I might be answering my own question here but I have the non BT tool for my 2002 TD6. Im planning on buying a 59 plate TDV8 this week and was wondering if i need to buy another IID tool or will mine work?
Post #505458 17th Feb 2019 12:33pm
i dont think it will .. you can upgrade to a BT version via GAP.....email GAP to confirm.
Post #505461 17th Feb 2019 12:45pm
azaroth
Switzerland 2013 Range Rover Vogue TDV6 Barolo Black
Shopping the IIDTool BT from Europe?
Hello gents
I have been reading through quite a number of posts here, but haven't been able to find out if there's a suitable online store recommended by the esteemed forum members that ships from a European warehouse. I'd love to avoid the hassle of import duties and the like, if possible. Any continental option you would be able to point me to? TIA, AZ
Post #506289 25th Feb 2019 11:53am
here you go,
https://www.fullfatrr.com/forum/topic47809.html
Post #506291 25th Feb 2019 11:56am
Andy
Re: Shopping the IIDTool BT from Europe?
Unnecessary quote removed
I just bought one direct from GAP as they do an exchange service for the old units. I was charged £54 by DHL.
Post #506292 25th Feb 2019 12:04pm
azaroth
Thank you Stan!
Appreciate it!
cheers, AZ
Post #506298 25th Feb 2019 12:58pm
Andy
My BT IID has just arrived and I've plugged it into my laptop to update it. However, nothing is happening. I don't have an activation code that I can see, so have I got to email GAP for this info?
Post #506312 25th Feb 2019 2:32pm
the GAP user manual [from our wiki] explains all,
https://www.fullfatrr.com/gallery/albums/u...lV3.00.pdf
Post #506315 25th Feb 2019 2:38pm
