Home > Technical (L322) > FBH operation with timed climate
Page 2 of 3 <123>
tractorfactor
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Zermatt Silver
Hi Paul,
Thanks for the info in your post. The FBH is voltage sensitive, think it cuts out at 10.5v from memory. I've bought a scope to see if i can view the k-bus signals between the FBH and the HVAC panel. I've also bought another FBH from a 2012 vogue. So will swap out asap. No guarantees this one is any better but at least i can compare with my original. Keep you posted Thumbs Up
TF
Post #503750 2nd Feb 2019 10:37pm
kooky_guy
Mine wouldn't run at 11.4V, although the car itself was perfectly happy. 2010 4.4 TDV8 Vogue SE
Post #503751 2nd Feb 2019 10:47pm
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
I had the E7 fault and the FBH wouldn't operate. Cured it with a 'Vehicle Reset' with the IID ... Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #503758 2nd Feb 2019 11:32pm
GGDR
as above the FBH needs a min battery voltage.
it also needs a minimum fuel level too.
I suppose to stop you running dry on the heater.
. Cheers, Greg
Post #503763 2nd Feb 2019 11:39pm
Andy
What does this actually do? I’ve seen this in IID. I’m getting E7 as well. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #535230 23rd Nov 2019 2:19pm
tractorfactor
Hi all,
Just to update you on my timed climate issue from my previous posts. Finally managed to speak with a knowledgeable technician in Inchcape Chester after an email to JLR direct about the service. Turns out it was a software issue all along, as I suspected. New software update or reboot and the timed climate is working off the infotainment screen and the remote. After all this time its finally working as it should Very Happy
Cheers TF
Post #543248 6th Feb 2020 6:58pm
DrRob
Good news. When it works it’s Censored brilliant piece of kit for pre warming the car on cold mornings Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #543253 6th Feb 2020 7:34pm
Andy
Good to hear. I wish I could get mine working without having to remove all of the wheel arch liner! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #543264 6th Feb 2020 8:52pm
tractorfactor
hi Andy
What is the problem with your fbh?
I've pretty much got to grips with all the physical side of the system so if I can help I will do.
Cheers, TF
Post #543272 6th Feb 2020 10:01pm
Andy
It doesn’t fire up. It sounds like it’s trying with the jet turbine sound from inside the wheel arch then it changes to a fan running. The fuel pump doesn’t start although it did one one occasion briefly. Like a ticking sound from the back. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #543278 6th Feb 2020 10:21pm
tractorfactor
Hi Andy,
They really are a simple unit when you split them. I'm a maintenance engineer so I don't like anything like this to beat me Laughing There are many posts on here regarding the FBH unit and I've read a lot of them. They are in effect a mini version of a central heating oil burner. Nothing new, my cousin had one in his sleeper wagon over 40 years ago, gees I'm getting old Sad As with any burner they through a series of safety checks before they will fire up.
If it was me I would whip the FBH out and check its not full of carbon or something else obvious. It's really not that difficult to get out. The worst bit by far is wrestling with the arch liner, it's what I imagine fighting a naggy octopus would be like Laughing
Remove the FBH exhaust and brackets then clamp both water hoses and gently release the fuel supply hose clip. If done carefully you will be able to reuse it. The cables are all on plugs. When you split it, just be careful you don't damage any gaskets but these are able to be purchased if needed. The gauze is delicate so don't stick anything through it. If the glow pin is faulty or damaged, again these are readily available.
If you haven't got the Webasto software and link cable to test the various components then carefully put a 12 volt supply across them. Even with the test gear you can only test the water pump, fan, glow pin and fuel pump operation. This is because the control board is running JLR software to run on their canbus. Basic Webasto units just need a permanent and switched supply to work just like your home boiler, not so the units in ours.
If you have something to clear faults great , if not pulling the FBH fuse for a few seconds will reset it.
Also have a look at the fuel pump unit. I have heard of some that rot from the outside due to the position under the car.
Let me know if I can help in any way Thumbs Up
TF
Post #543283 6th Feb 2020 10:59pm
Andy
I have pulled the fuse a couple of times but it doesn’t make any difference. I’ve tried to check the operation with the IID tool but just keeps failing with a fault code which no-one seems to know what the code is.
I’m just going to go have to set a day or two aside and remove it. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #543286 6th Feb 2020 11:13pm
kooky_guy
Re: FBH operation with timed climate
tractorfactor wrote:
Hi all,
Cheers TF
Do you have any more information on the software update? It seesm odd that a car of your age would have out of date software - I assume this relates to the battery managenment? 2010 4.4 TDV8 Vogue SE
Post #543636 11th Feb 2020 10:24am
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
Hope you don't mind if I hijack the thread with a query re the FBH. I have a 2020 autobiography and the FBH works fine off the JLR remote fob but when I try to use it via the inControl app it starts the engine after about 20 seconds. Is this normal? Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #585558 27th Feb 2021 5:02pm
mjdronfield
This is in the L322 Technical Section, so not many L405 owners looking in here.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #585559 27th Feb 2021 5:05pm
Page 2 of 3 <123>
