Home > Technical (L322) > The old "no sound" help
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Hi everyone.
Picked up a 2004 Vogue yesterday, and there is no sound from anything on the stereo. Having read previous threads, I can tell you the following:
I have checked for water and all seems dry in there (although it has been wet before).
The headunit does show DSP as an option.
I have removed all the boxes from the back (amp, DSP, TV tuner etc) and pins and connectors seem OK.
There IS an orange dot when I power up on the HU-and all the buttons work (eg the radio tunes OK and the CD registers).
Now the ODD thing. I removed the fuse from the main fuse box for audio, and very briefly everything worked OK-all speakers were good but it went off after 3 mins or so. And removing the fuse a second time did nothing.
Any help is very much appreciated.
Thank you
Phil
Post #503896 4th Feb 2019 12:45pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Phil,
Get inside the boxes and look for any kind of crusty stuff white or green!
I bet you'll find some!
Bushy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #503897 4th Feb 2019 12:49pm
philip1972
Thanks-I have been inside the BM54, that looked good.
Do i need to open the DSP do you think?
The one box that looks as if its been wet is the TV module. Now, I dont want or need that to work, but could that box affect the sound as well?
Thanks again Thumbs Up
Post #503898 4th Feb 2019 12:51pm
Bushy30
Hi Phil,
Yes indeed -- they can all mess with things -- best to inspect both sides of all boards Very Happy
Previous: -
Post #503900 4th Feb 2019 1:06pm
As above you really need to look inside the various module cases for corrosion.
You could also check the 10A fuse on the top of the bm54 radio tuner.
I seem to recall you can byepass the tv module by uncliping the two plugs and joining them together but I could be wrong.
Post #503901 4th Feb 2019 1:12pm
philip1972
Thanks all.
This afternoon will spent taking them all to bit lol
Post #503902 4th Feb 2019 1:14pm
gj88
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
With sound off and screen on, I'd start with the DSP and then work your way out. Good chance it'll be that one
Post #503903 4th Feb 2019 1:28pm
SilverParrot
Same fault on mine was caused by a dodgy pin on the DSP
Post #503904 4th Feb 2019 1:49pm
philip1972
I am getting confused here with whats what!!! Boxes in there are the DSP, Amp, TV, nav radio module etc etc Censored )
What does the DSP look like exactly?
Post #503908 4th Feb 2019 2:23pm
It's the vertical black box with 3 plugs on the top nearest the back of the car. Thumbs Up
Post #503909 4th Feb 2019 2:26pm
philip1972
Found a wet and dirty connector on the top of the TV module. Not sure if that can affect things but will clean anyway
Post #503910 4th Feb 2019 2:30pm
Bushy30
Thumbs Up Don't assume that it'll be the only one -- the inside of my DSP was GREEN and crusty! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #503911 4th Feb 2019 2:35pm
philip1972
Whats the best way to clean the pins and socket?
Its pretty crowded in there and the socket cannot be di assembled and my fat sausage fingers are not going to fit in there Very Happy
Post #503912 4th Feb 2019 2:45pm
Bushy30
Use a good contact cleaner with a soft toothbrush - -and don't brush too hard Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #503914 4th Feb 2019 2:58pm
The three plugs can definitely be undone. You definitely need to get the biggest plug undone and check for corrosion. There is a slide clip on the plug you need to undo before the plug will come out.
Contact cleaner is you best bet for cleaning.
Be very careful, the pins in the sockets are very thin, even more so if they have corroded.
Post #503915 4th Feb 2019 2:58pm
