![]() | Home > Technical (L322) > The old "no sound" help |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1102 ![]() ![]() ![]() |
Phil,
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
Thanks-I have been inside the BM54, that looked good.
Hi Phil,
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3986 ![]() ![]() ![]() |
As above you really need to look inside the various module cases for corrosion.
Thanks all.
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 ![]() ![]() ![]() |
With sound off and screen on, I'd start with the DSP and then work your way out. Good chance it'll be that one |
SilverParrot Member Since: 09 Aug 2018 Location: Herts Posts: 25 ![]() ![]() ![]() |
Same fault on mine was caused by a dodgy pin on the DSP |
I am getting confused here with whats what!!! Boxes in there are the DSP, Amp, TV, nav radio module etc etc |
It's the vertical black box with 3 plugs on the top nearest the back of the car. |
Found a wet and dirty connector on the top of the TV module. Not sure if that can affect things but will clean anyway |
Whats the best way to clean the pins and socket?
Use a good contact cleaner with a soft toothbrush - -and don't brush too hard |
The three plugs can definitely be undone. You definitely need to get the biggest plug undone and check for corrosion. There is a slide clip on the plug you need to undo before the plug will come out.
