![]() | Home > Technical (L322) > Next question-grabbing while cornering |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2748 ![]() ![]() |
This sounds like the known problem of the centre diff grabbing, for which the cure is flushing the transfer case then recalibrating it. |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
ooooh dear, that sound difficult=expensive |
How hard was the cornering? |
Well today I was trying quite hard-I would normally drive like that but at least it was on an airfield |
A double oil change for the TC then invoke self-calibration using a diagnostic tool, so not expensive. However if the apparent fault occurs in a straight line then not a TC problem. |
Al sounds very technical GraemeS... The Top Gear evoking airfield image had my lay perspective thinking, "It's a Range Rover not an Aston Martin" |
So Graeme, I took it out this afternoon and the traction control activated while accelerating (gently) in a straight line...... What does that mean then ![]() |
Activating on gentle straight-line acceleration - assuming that all tyres are the same size then it is sounding like a faulty ABS sensor that's producing more pulses than it should be. Can you feel the steering pulling one way or the other, suggesting a front wheel that is grabbing? |
Wasn't being very gentle-if I drive REALLY gently its OK.
