![]() | Home > Maintenance & Mods (L405) > L405 Service due message |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2709 ![]() ![]() ![]() |
Shouldn't really reply to my own thread, should have googled it 1st, seemingly rather easy:
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1417 ![]() ![]() ![]() |
Just in case there is more to it: My car started throwing up inappropriate service messages when relatively new. It needed a software update, apparently a common problem. With some models there is also the dilution of engine oil with diesel due to regeneration being stopped, typically on cars used for short journeys, that necessitates more frequent oil changes, see other threads on here about that problem, which can lead to service due messages sooner than expected, but in that case for good reason. Only Range Rovers since 1988 |
Ocean53 Member Since: 14 Feb 2018 Location: Chichester Posts: 83 ![]() ![]() ![]() |
That doesn’t clear the message on LAND ROVER REMOTE. Any idea how to clear that when you have booked your service a month ahead
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 234 ![]() ![]() |
This procedure only resets the oil dilution counter.
Oh ffs, more expense... |
Bit the bullet, booked in for diagnostic next Tuesday, will report back |
chopdogs Member Since: 17 Feb 2011 Location: Malmesbury, Wilts Posts: 40 ![]() ![]() |
Mine threw up a “Service due in 1,800 miles” message yesterday. Today it’s down changed to 500 miles and I’ve only driven about 70 miles in between.
Well I sat and waited, they did a health check, could find no reason why it flashed up, although the rear diff is leaking, so something for the future. |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1502 ![]() ![]() ![]() |
Helpful |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Fantastic tip
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
That will end up in needing a new diff. See other threads on this well known issue. ![]() |
