Home > Maintenance & Mods (L405) > L405 Service due message
Mr Tee
Afternoon All,
car flashed up this morning , service due 1700 miles.
lunch time - service due.
Only had the damn thing since November, it's last service was 30/8/18 80k mile service , it's only done less than 3k since. So it looks like the service indicator wasn't re-set. Is there any way I can do this without an obd reader? I know its a 1st world problem , but will be annoying AF every time it's started . Thumbs Up
Post #504300 7th Feb 2019 2:52pm
Mr Tee
Shouldn't really reply to my own thread, should have googled it 1st, seemingly rather easy:
Post #504302 7th Feb 2019 3:00pm
CS
Just in case there is more to it: My car started throwing up inappropriate service messages when relatively new. It needed a software update, apparently a common problem. With some models there is also the dilution of engine oil with diesel due to regeneration being stopped, typically on cars used for short journeys, that necessitates more frequent oil changes, see other threads on here about that problem, which can lead to service due messages sooner than expected, but in that case for good reason. Only Range Rovers since 1988
Post #504303 7th Feb 2019 3:37pm
Ocean53
United Kingdom 2018 Range Rover Vogue SDV6 Corris Grey
That doesn’t clear the message on LAND ROVER REMOTE. Any idea how to clear that when you have booked your service a month ahead
( clearing the dash message was very helpful thanks)
Post #504324 7th Feb 2019 5:14pm
Fifth Horseman
Scotland 2018 Range Rover Vogue SE SDV8 Carpathian Grey
This procedure only resets the oil dilution counter.
Resetting the time/distance countdown (which generates the message on L/R remote) requires diagnostic equipment (IIDTool or similar).
Post #504842 11th Feb 2019 6:55pm
Mr Tee
Oh ffs, more expense...
Post #504847 11th Feb 2019 8:06pm
Mr Tee
Bit the bullet, booked in for diagnostic next Tuesday, will report back
Post #504892 12th Feb 2019 11:41am
chopdogs
Mine threw up a “Service due in 1,800 miles” message yesterday. Today it’s down changed to 500 miles and I’ve only driven about 70 miles in between.
Any ideas why this might be?
Thanks
Post #507188 3rd Mar 2019 7:33pm
Mr Tee
Well I sat and waited, they did a health check, could find no reason why it flashed up, although the rear diff is leaking, so something for the future.
Post #507248 4th Mar 2019 8:20am
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Helpful Thumbs Up
Post #507253 4th Mar 2019 9:26am
wealy
Fantastic tip
Post #532061 25th Oct 2019 9:59am
DrF
Post #532062 25th Oct 2019 10:00am
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
Mr Tee wrote:
... although the rear diff is leaking, so something for the future.
That will end up in needing a new diff. See other threads on this well known issue. Sad
Post #532093 25th Oct 2019 12:48pm
