![]() | Home > Technical (L322) > park heating |
| MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 547
Depends on outside temperature but I would say 15 min is the absolute minimum to have much effect on mine. Takes the edge off though and positively toasty if you leave it a little longer. 2016 Skoda Octavia VRS Estate
| dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529
Ah so sounds like mine is working ok.
| Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193
Turns off after 30 min. Mine takes 20-25 min to be teally noticeable if outside is frosty. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8001
Think itโs less on the later cars....my manual says 20 min if I remember right. Was 30 min on my TD6.
Thanks buddy ๐๐ป |
Apologies, looks like 30 mins still....I must have seen 20 somewhere |
| dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724
If you get into the RR after 20 mins and the FBH is working properly then it should be toasty. I find that if you get in 5 mins after the FBH has stopped then the RR is already starting to cool. 2015 4.4 AB
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951
We've just bought a 2010 MY 3.6 SE. I have a T91 remote that i bought two years ago and I'm wondering how to pair it with the car if anyone can assist? |
| mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 913
Check the Wiki or do a search Andy.
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Turn up the heat setting the night before to full and it will be really toasty the next day. Works for me on the timed option. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Top of my head re the pairing but i think its disconnect the power to the FBH receiver by the fuse board in the re rear right ( as your
| rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198
For an 11MY this works, possibly the same for yours Andy.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35880
Thanks all |
| All times are GMT |
