Home > Technical (L322) > park heating
Page 1 of 3 123>
dazza1983
park heating
Hey guys,
i just got a 2011 Vogue 3 days ago, so im still figuring out all is toys and what not lol,
I have the fuel burning heater and im just trying to figure out if its working properly, i think it is
I turn on the remote and i can hear the thing fire up sounds like a turbine and then clicking every few seconds, the blowers do blow but after 15 mins or so the cabin is only luke warmish its not hot
Is this normal?
Cheers
daz
Post #505716 19th Feb 2019 8:29pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Depends on outside temperature but I would say 15 min is the absolute minimum to have much effect on mine. Takes the edge off though and positively toasty if you leave it a little longer. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #505726 19th Feb 2019 9:35pm
dazza1983
Ah so sounds like mine is working ok.
Thanks buddy.
Donโ€™t these cut out after so long anyways?
Daz
Post #505727 19th Feb 2019 9:39pm
Nick591
Turns off after 30 min. Mine takes 20-25 min to be teally noticeable if outside is frosty. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #505735 19th Feb 2019 10:35pm
mjdronfield
Think itโ€™s less on the later cars....my manual says 20 min if I remember right. Was 30 min on my TD6.
Depends on lots of things when it comes on, battery voltage, outside temperature, fuel level....
It gets warm enough to defrost Windows, but thatโ€™s about it.
Yours sounds like itโ€™s working fine to me.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #505736 19th Feb 2019 10:39pm
dazza1983
Thanks buddy ๐Ÿ‘Œ๐Ÿป
Post #505739 19th Feb 2019 10:46pm
mjdronfield
Apologies, looks like 30 mins still....I must have seen 20 somewhere Rolling with laughter
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #505741 19th Feb 2019 11:01pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
If you get into the RR after 20 mins and the FBH is working properly then it should be toasty. I find that if you get in 5 mins after the FBH has stopped then the RR is already starting to cool. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #505742 19th Feb 2019 11:01pm
Andy
We've just bought a 2010 MY 3.6 SE. I have a T91 remote that i bought two years ago and I'm wondering how to pair it with the car if anyone can assist?
Post #505749 20th Feb 2019 12:49am
mpirie
Check the Wiki or do a search Andy.
Pairing the remote involves pulling a fuse, but I can't remember the sequence.
Mike
Post #505777 20th Feb 2019 9:41am
DrRob
Turn up the heat setting the night before to full and it will be really toasty the next day. Works for me on the timed option. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #505788 20th Feb 2019 10:58am
dolph34
Top of my head re the pairing but i think its disconnect the power to the FBH receiver by the fuse board in the re rear right ( as your
looking from the back of the RR) panel. Press the ' off ' button on the T91 and replug in the power lead to the FBH receiver and robert in your dads brother ๐Ÿ‘๐Ÿ‘๐Ÿ‘ ( i think ) 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #505803 20th Feb 2019 1:23pm
rjff
For an 11MY this works, possibly the same for yours Andy.
Remove fuse 16 (5amp) in the rear load space fuse box
Replace it and within 5 seconds press the OFF button on the remote for at lest 1 second.
To confirm, press the off button and a continuous red light will show if successful. If flashing, pairing failed. check remote batttery and repeat.
Read somewhere that of the light is orange-ish, the remote battery is failing/failed. Cheers
Richard
Gap IIDBT
Post #505816 20th Feb 2019 3:24pm
http://www.fullfatrr.com/gallery/albums/us...ing.~0.pdf
Post #505818 20th Feb 2019 3:31pm
Andy
Thanks all
Post #505841 20th Feb 2019 7:42pm
Page 1 of 3 123>
