![]() | Home > Duckworth Parts > 2012 L322 LHD Headlights |
ilard Member Since: 21 Oct 2012 Location: London Posts: 715 ![]() ![]() |
Isn’t there a mechanical lever behind the rear dome on each headlight to switch it to LHD countries? |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 436 ![]() ![]() ![]() |
Each headlamp unit has a mechanical lever which simply 'flattens' the beam so you don't dazzle oncoming traffic - which is what I'm currently doing.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1404 ![]() ![]() |
try putting it through the test first with the lever flattening the beam and the lamps adjusted to point more towards the right.
Thanks, Dingg1 - certainly worth the cost of the test vs €sss on new lights.
is that cost using an agent?
Yes, using an agent - their fee is about €600, the rest is the tax on the value of the car + Co2 emissions.
Road tax I guess you mean?
The road is very reasonable, less than half that of the UK.
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 ![]() ![]() |
will most likely work out cheaper returning to the UK
Thanks, Dan, inclined to agree with you - simply not worth the cost. All to essentially have a different number plate! |
Tommy
Just had mine tested for matriculation in portugal and all passed , headlights needed some adjustment but done by the tester (rhd lights still fitted but lever to europe setting) |
Hi, I'd love my to pass its matriculation but my mechanic advised the lights don't 'throw up' enough light, you can see how flat they are with the Tourist mode enabled. Well done though!
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
It’s a dead easy (and toll free) trip down from Alicante to Faro.
