Home > Range Rover P38 > Air suspension
Andyv8
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Java Black
Air suspension
Is there a way to make the air suspension operate with out the engine running? I’m thinking of doing a engine swap on one with a knackered 4.6 but would like to keep the air suspension active. I’m guessing the becm gets its reading from the engine and then activates the eas?
Post #506422 26th Feb 2019 8:04am
Benfelrr
United Kingdom 2007 Range Rover Vogue TDV8 Tonga Green
yes there is, I will ask my mate who did it on his how its done and pass on what he says. 2011 Range Rover Vogue 4.4 TDV8
2003 VW Golf V6 4motion
2001 Range Rover Vogue 4.6
1982 Range Rover in VOGUE
1990 Range Rover Vogue SE
2007 Audi A6 Avant Le Mans Quattro S-Line 3.0 TDI
2007 Skoda Ovtavia 2.0 TDI L&K
2007 GSX-R 750 K7
Post #506504 26th Feb 2019 7:18pm
Andyv8
Cheers
Post #506507 26th Feb 2019 8:24pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
You could fit something like this
https://rover.ebay.com/rover/0/0/0?mpre=ht...2595547625
I fitted something similar to mine just in case I got stuck........
Cheers ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #506517 26th Feb 2019 9:24pm
kooky_guy
You can certainly operate it with diagnostics software (ie EAS Unlock) without the engine running. 2010 4.4 TDV8 Vogue SE
Post #506557 27th Feb 2019 9:11am
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
I second what UK Marine says.
I have that exact system on my P38, which has been valuable beyond words. From the same seller.
Over Xmas I had the entire front end stripped down and spend many days under the car, would have been impossible without the inflation device.
Just get a good foot pump and or compressor and keep and eye on the PSI.
Looks hilarious to be stood by the Range Rover pumping it up by foot like a bike Rolling with laughter
Post #506560 27th Feb 2019 9:42am
UK Marine
But you can't recharge the air tank without the engine running. Thats the point of the extra air valves set up I mentioned, you put air directly into each air spring as needed..... Thumbs Up ______________________________
Simon
Post #506592 27th Feb 2019 3:56pm
Benfelrr
He says he did it using nanocom when re calibrating the air suspension. Ran the compressor without the engine running, though ignition was on and lifted the car up. Not sure how removing the engine will effect a non error ignition though? But certainly could run the compressor and raise suspension without engine running via nanocom. 2011 Range Rover Vogue 4.4 TDV8
2007 GSX-R 750 K7
Post #506664 28th Feb 2019 2:07pm
UK Marine
That is true you can activate the compressor, but in the long run when parked waiting for your missus and with a boot full of shopping you get a suspension fault.
It then drops to the bump stops and your missus turns up just when it starts raining and your left trying to explain how you’re going to fix it without your diagnostics, that you left at home...... ask me how I know Very Happy
That’s why I fitted that valve kit, it’s completely independent of the compressor and can be used with a foot pump, portable tyre inflator or a filling station air line. I’ve had a few P38s and they all, without exception, had suspension failures.
Just view the valve kit as future proofing Thumbs Up ______________________________
Simon
Post #506738 28th Feb 2019 9:20pm
kooky_guy
I used to run my compressor quite a lot to fill the tank when I was playing around with mine so it certainly can be done without the engine running (this was with EAS Unlock).
It will flatten the battery eventually, but I assume that isn't a problem in this scenario. 2010 4.4 TDV8 Vogue SE
Post #506791 1st Mar 2019 9:34am
