Home > Range Rover P38 > Air suspension |
Benfelrr Member Since: 27 May 2012 Location: Wiltshire Posts: 279 |
yes there is, I will ask my mate who did it on his how its done and pass on what he says. 2003 VW Golf V6 4motion
26th Feb 2019 7:18pm |
Andyv8 Member Since: 02 Feb 2019 Location: Lakes Posts: 15 |
Cheers |
26th Feb 2019 8:24pm |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 818 |
You could fit something like this
26th Feb 2019 9:24pm |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
You can certainly operate it with diagnostics software (ie EAS Unlock) without the engine running. 2010 4.4 TDV8 Vogue SE |
27th Feb 2019 9:11am |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 391 |
I second what UK Marine says.
27th Feb 2019 9:42am |
But you can't recharge the air tank without the engine running. Thats the point of the extra air valves set up I mentioned, you put air directly into each air spring as needed..... ______________________________ Simon ______________________________ Range Rover Classic 3.5 efi - Gone Range Rover Classic 3.9 efi - Gone Range Rover Classic 4.2 LSE - Sadly gone Land Rover 110 3.5 - Gone Range Rover P38a 4.0 SE - Pleased it's gone Range Rover P38a 2.5 DHSE - Just sold Range Rover L322 4.4 v8 Petrol - Current |
27th Feb 2019 3:56pm |
He says he did it using nanocom when re calibrating the air suspension. Ran the compressor without the engine running, though ignition was on and lifted the car up. Not sure how removing the engine will effect a non error ignition though? But certainly could run the compressor and raise suspension without engine running via nanocom. 2003 VW Golf V6 4motion
28th Feb 2019 2:07pm |
That is true you can activate the compressor, but in the long run when parked waiting for your missus and with a boot full of shopping you get a suspension fault.
28th Feb 2019 9:20pm |
I used to run my compressor quite a lot to fill the tank when I was playing around with mine so it certainly can be done without the engine running (this was with EAS Unlock).
1st Mar 2019 9:34am |
