Home > Maintenance & Mods (L405) > Oil |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3675 |
If you go to the “Opie Oils” website and enter your car Reg it will offer you several suitable oils.
1st Mar 2019 9:37pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16170 |
Roberlar, have a look at your coolant bottle... Is it really clean and clear? The early 405's have a tendency for oil cooler failure! Mixing oil and coolant, on a run they start to stink usually...
2nd Mar 2019 12:40am |
roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203 |
Thanks for the replies. I originally picked up some Edge Titanium LL but on checking the spec it's different to the professional. I then looked on the Opie Oils website which stated ' Castrol Edge 5w-30 LL FST fully synthetic engine oil can be used instead of Castrol Edge Professional 5W-30 FST, products that are mainly only available from dealerships and are generally a lot more expensive with similar / same specifications'. However I then emailed them and they said don't use it as the oil needs to meet Ford spec ending 934B. Therefore it seems I either need the Professional Edge or Helix AF-L or equivalent.
2nd Mar 2019 10:21am |
http://www.fullfatrr.com/forum/topic48509.html
2nd Mar 2019 10:32am |
