Hi all, I have a question regarding my L405 2013 SDV8 AB. Checked oil level July 18--ok. Checked again December 2018, showed as over filled but depending on where it was parked. Sucked 1 pint out and showed ok on the level or a very slight incline. Checked again Feb 2019 showed over filled again, but depending on where it was parked. Car has only covered about 4k miles since last main dealer service. I do tend to drive a lot of local miles, although many of these roads are quite fast so can't imagine I'm bunging up the DPF or forcing diesel in to the oil. Have also done a few long motorway stints as well. No warnings on the dash. None the less, as an interim precaution I think I ought to change the oil and filter as assuming the electronic dipstick is accurate, somethings getting in there. I believe there may be a slight coolant leak as I can often smell anti freeze after a run. However the amount of coolant required to top up is minimal and doesn't stack up to the oil level increase. Furthermore, getting hold of the right engine oil seems to be a challenge. I know the recommended oil is Castrol Edge 5W-30 Professional but this seems to be main dealer only. With regards to oil quality, a respected local garage said 'it's a bit like wearing Asda George jeans compared with Georgio Armani Jeans.....there's not much in it other than the price'. Any thoughts much appreciated.
