![]() | Home > Technical (L322) > Carphone-wont light up. |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
Are you certain the sim is in correctly?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
i would look at the initial problem of the handset not powering up...change the battery's and look at the connections .. ... - .- -.
I believe the system should still operate even if the battery is out of the handset. The handset itself is only there for making phone calls when you want to get out of the car.
I've just checked mine, even if I take the bateries out the system still works.
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
Also make sure your sim is GSM - Vodafone or O2 network only - Orange or Three wont work! |
KARMANN Member Since: 13 Dec 2010 Location: Scotland Posts: 95 ![]() ![]() |
Yeah I have an O2 sim inserted the correct way. I have checked the master switch aswell. So it seems I have an issue with the handset not getting power when its in the craddle-looks like the cradle might be disconnected? Where in the car are the modules etc that operate the phone?
As I said, the handset doesnt need to have power, or be present for the system to work. The workshop manual gives a good overview of the various components the phone system uses and their locations, you should check each of them to ensure their plugs are well seated etc and also for water damage. ![]() |
surely the handset needs power to work, maybe not battery but certainly the cars power.. ... - .- -.
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
As Dan says, handset is totally irrelevant. Mine's never worked, but I used the carphone all the time. Why would you want to use the handset? If you're driving you'll want to be handsfree via the microphone etc. For dialling you use voice control or the satnav control screen.
I need the handset to delete texts - I cant delete them from the screen |
I don't use texts on the carphone, since it has a separate sim. Do you have your main mobile connected via bluetooth?
I appreciate it should be possible - and I have the button to do it. However when I press delete it does nothing |
These are the components relating to the factory fitted phone kit. Apart from the cradle and handset (obviously!) the rest are located in the rear near side panel with the rest of the audio/tv & nav modules, if fitted.
makes sense doctor dan.. |
