Home > Technical (L322) > Carphone-wont light up.
KARMANN
2002 Range Rover Vogue 4.4 V8 Java Black
I have an 02 plate l322 and was playing about and wondered how to get the carphone working. I installed a new simcard in the slot and put new batteries in the handset but the handset wont power up. Is it common for these handsets to become faulty? Or am I missing a trick. The simcar I have installed is an O2 sim but on the monitor screen under the telephone option it still says Install Sim.
Fraser
Post #50518 16th Feb 2011 6:52pm
Are you certain the sim is in correctly?
I recall the old handset type, I had that in my M5. PITA !
I'd rather spend a few hundred quid on a parrot system with bluetooth and have something up to date plumbed into the phone system instead. Just my opinion. Discovery 4 HSE
1993 90 Tdi
Post #50522 16th Feb 2011 7:08pm
i would look at the initial problem of the handset not powering up...change the battery's and look at the connections .. ... - .- -.
Post #50524 16th Feb 2011 7:13pm
dan_uk_1984
I believe the system should still operate even if the battery is out of the handset. The handset itself is only there for making phone calls when you want to get out of the car.
Dan
Post #50526 16th Feb 2011 7:22pm
dan_uk_1984
I've just checked mine, even if I take the bateries out the system still works.
Have you tried the master switch:
Range Rover Phone - Off Switch by d86cfv, on Flickr
The sim should go this way:
Range Rover Phone - Sim Card by d86cfv, on Flickr
More pics of the phone system HERE
Post #50533 16th Feb 2011 7:53pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
Also make sure your sim is GSM - Vodafone or O2 network only - Orange or Three wont work! Thumbs Up 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #50595 17th Feb 2011 10:41am
KARMANN
Yeah I have an O2 sim inserted the correct way. I have checked the master switch aswell. So it seems I have an issue with the handset not getting power when its in the craddle-looks like the cradle might be disconnected? Where in the car are the modules etc that operate the phone?
The sim is brand new and has never been used-but doubt that would have an effect on the phone not getting power?
Fraser
Post #50694 18th Feb 2011 1:12am
dan_uk_1984
KARMANN wrote:
It seems I have an issue with the handset not getting power when its in the craddle
As I said, the handset doesnt need to have power, or be present for the system to work.
The workshop manual gives a good overview of the various components the phone system uses and their locations, you should check each of them to ensure their plugs are well seated etc and also for water damage.
Post #50699 18th Feb 2011 9:16am
surely the handset needs power to work, maybe not battery but certainly the cars power.. ... - .- -.
Post #50701 18th Feb 2011 9:34am
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
As Dan says, handset is totally irrelevant. Mine's never worked, but I used the carphone all the time. Why would you want to use the handset? If you're driving you'll want to be handsfree via the microphone etc. For dialling you use voice control or the satnav control screen.
The batteries in the handset are rechargeable, but I never bothered to replace mine for the reasons above. Best thing is to just ignore the handset totally. 2012 SDV8 Vogue SE
Post #50703 18th Feb 2011 9:42am
dan_uk_1984
I need the handset to delete texts - I cant delete them from the screen Sad
Post #50731 18th Feb 2011 10:50am
bozmandb9
I don't use texts on the carphone, since it has a separate sim. Do you have your main mobile connected via bluetooth?
Can't imagine using texts much from the carphone. I would have thought it would be possible to delete texts from the screen. Looking at the instruction manual for the phone, the relevant page seems to be page 37:
'Call up the sub menu, select "Delete text" and confirm' 2012 SDV8 Vogue SE
Post #50734 18th Feb 2011 10:56am
dan_uk_1984
I appreciate it should be possible - and I have the button to do it. However when I press delete it does nothing Sad
I can delete using the handset fine.
The reason I use texts is I text myself the address where I'm going to, or sometimes to-do lists. The real PITA is that the phone doesn't support VCards.
I'd like to get into the "BMW Assist" code at some point and figure out how to send addresses directly to the Nav as per google "send to bmw"
Post #50735 18th Feb 2011 11:05am
Ajay(UK)
These are the components relating to the factory fitted phone kit. Apart from the cradle and handset (obviously!) the rest are located in the rear near side panel with the rest of the audio/tv & nav modules, if fitted.
For anyone still confused about why the handset doesn't need to be operational just compare the kit to a simple home phone.........The module is the brain of a fixed handset with the keypad located on the monitor up front and works just like any normal phone (assuming working sim etc). The bluetooth handset in the centre console is just an extension handset, in the same way as if you have a separate cordless handset at home, when the batteries die on any cordless handset you can still make and receive calls using any other phone in the house. This kit is no different.
"Incorrect SIM" would indicate a problem with the SIM itself or the cradle that reads the SIM, the fact that you have this message on the monitor and that the "telephone" option is displayed in the menu would indicate that is unlikely to be a wiring issue.
Andy.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
Post #50738 18th Feb 2011 11:32am
makes sense doctor dan.. Thumbs Up ... - .- -.
Post #50740 18th Feb 2011 12:32pm
