Home > Maintenance & Mods (L322) > Rear flexI brake hoses
Danwilderspin
Hi all spending quite a bit on the ff as it’s mot month. The rear brake flexis will need changing soon but the pair are just shy of £200 from Dan. Has anyone come across the brand allmakes as they do their own version of them for 1/4 price. Anyone used these? Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #508472 12th Mar 2019 7:25pm
https://www.island-4x4.co.uk/brake-flexi-h...-8081.html .
Post #508474 12th Mar 2019 7:40pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Hi Dan,
you sure about the part number???, its LR058025 / 26 left and right. I bought mine in 2015 and then they were £31.78 +vat each from Duckworth. I'm assuming we have the same rear flexi's.
I found these people selling them:- https://www.lrdirect.com/LR058025-supplied...d-OEM.html
Post #508477 12th Mar 2019 7:45pm
Danwilderspin
Yea it is different 02-06 I’m guessing you are 06+ - joe those britpart ones are right what are they like compared to genuine? Cheers Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #508494 12th Mar 2019 9:21pm
£50 a side cheaper....(ex VAT) Smile
but they are your brakes, so you decide, but I guess even Britpart couldn't get away with making shoddy brake pipes (awaits flame war!) .
Post #508511 12th Mar 2019 11:34pm
finchi
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
I would recommend only fitting standard LR supplied rear brake flexible hoses. I had an issue with non standard flexi-hoses that had been previously fitted and were rubbing on suspension/ hub strut. The tolerances of movement and potential for rubbing are very tight, and it was suspected that the "copy" hoses were slightly too long.
Post #508527 13th Mar 2019 8:47am
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
It's all very confusing are OEM parts the same as genuine parts , are aftermarket parts any good , I would think any parts would have to meet safety standards or is that not the case Neutral Thumbs Up
Post #508529 13th Mar 2019 9:15am
Danwilderspin
good question - has anyone had any experience of none genuine ones aside from finchi? Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #508531 13th Mar 2019 9:19am
Fraynizzle
United Kingdom 2005 Range Rover Vogue Td6 Java Black
Genuine parts will be known and signed off by LR to have been tested by the supplier to meet the LR specifications.
OEM parts will be from the same original supplier to LR but not necessarily to the same testing standards. normally less testing because that's how they offer them at a lower price.
aftermarket will be from any supplier and tested to their own specifications which may or may not relate at all to the market/vehicle the parts are intended for or not tested at all if the are really cheap!!!
Post #508533 13th Mar 2019 9:30am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Beware the definition of OEM parts has been distorted over the last few years to mean only that the supplier is (or was !) a supplier to Land Rover - not necessarily of the parts you're interested in !
The worst example I've seen is Unipart parts identified as OEM when as far as I know they only supplied aftermarket parts to LR - never anything that went into brand new vehicle. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #508544 13th Mar 2019 10:10am
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
personally i wouldnt fit genuine. i have fitted non genuine flexible pipes to quite a few vehicles (50?) over the last 10years and none of them have failed. Cheers
James
Post #508554 13th Mar 2019 11:21am
Danwilderspin
JST what brand do you use? Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #508556 13th Mar 2019 11:41am
JST
i have always had them made to order by Llama4x4. Cheers
James
Post #508622 13th Mar 2019 7:53pm
jamesg25
United Kingdom 2012 Range Rover Autobiography TDV8 Nara Bronze
Sorry to revive an old thread...
I recently took my - new to me - fatty to LR for the front brake safety recall, credit it where it was due a very slick and seamless job they did, free curtesy car an'all.
However they also noted that the rear break lines were badly corroded and advised replacement.
Has any one actually had a set of stainless braided lines made up for the rear? - Just spoke to David at Llama - he advised he'd be able to make a set up.
anything I should look out for, or any particular reason to go with genuine parts?
Cheers in advance.
James.
Post #563532 4th Aug 2020 9:51am
