![]() | Home > Maintenance & Mods (L322) > Rear flexI brake hoses |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
https://www.island-4x4.co.uk/brake-flexi-h...-8081.html .
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 508 ![]() ![]() ![]() |
Hi Dan,
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
Yea it is different 02-06 I’m guessing you are 06+ - joe those britpart ones are right what are they like compared to genuine? Cheers Current stable:
£50 a side cheaper....(ex VAT) |
finchi Member Since: 25 May 2017 Location: Hampshire and Cheshire Posts: 120 ![]() ![]() ![]() |
I would recommend only fitting standard LR supplied rear brake flexible hoses. I had an issue with non standard flexi-hoses that had been previously fitted and were rubbing on suspension/ hub strut. The tolerances of movement and potential for rubbing are very tight, and it was suspected that the "copy" hoses were slightly too long. |
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 ![]() ![]() ![]() |
It's all very confusing are OEM parts the same as genuine parts , are aftermarket parts any good , I would think any parts would have to meet safety standards or is that not the case |
good question - has anyone had any experience of none genuine ones aside from finchi? Current stable:
Fraynizzle Member Since: 27 Apr 2015 Location: Essex Posts: 111 ![]() ![]() ![]() |
Genuine parts will be known and signed off by LR to have been tested by the supplier to meet the LR specifications.
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 709 ![]() ![]() ![]() |
Beware the definition of OEM parts has been distorted over the last few years to mean only that the supplier is (or was !) a supplier to Land Rover - not necessarily of the parts you're interested in !
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
personally i wouldnt fit genuine. i have fitted non genuine flexible pipes to quite a few vehicles (50?) over the last 10years and none of them have failed. Cheers
JST what brand do you use? Current stable:
i have always had them made to order by Llama4x4. Cheers
jamesg25 Member Since: 07 May 2020 Location: Warwickshire Posts: 24 ![]() ![]() ![]() |
Sorry to revive an old thread...
